Lets say I found a full vetter set for cheap..
  • sparkfly88
    • Mar 2013
    • 585
    • CedarKey FL
    But, its off of a Kawi 1300....
    Fairing has an empty radio slot, with an antenna mounted next to it
    Matching saddlebags, and matching trunk.
    I know the trunk is universal, and I would love to have it.
    The saddlebags have their mounts, but looking on the forum shows a little metal work, and they'll mount onto my Xs.
    Looking at the fairing mount, its nowhere close to the XS, So I'd either have to fab one up, or find a mount online..
    My bike is a dark blue, the Vetter kit is black...I think it would look pretty cool.
    Anything I need to know?
    79F
    "Excelsior"
    Honda gl1100 handlebar
    Vetter IV fairing with speaker system
    OE headers,Jardine slipons
    Hid headlight 6000k
    Stock jets
    Shinko 712 F & R
    Oe hardbags and luggage rack
    TC fuse block
    K&n filter with oe airbox
    Raptor 660 Acct
  • GLoweVA
    • Jun 2011
    • 1957
    • Virginia Beach, VA.
    Cool. There are a few different WJ styles (III, V) whichever kind you got, they will all fit. (they have the same mounting hole locations)
    Did you get the pigtail wiring harness that came off the Kawi?
    It'll be a 9 pin (or 6 pin for the WJ3) plug that plugs into the left inside side of the fairing and has many loose wires on the other end to be plugged into your bike.
    If so, you can make this work, otherwise, start searching for a WJ harness.
    Now you will need the Vetter fairing bracket for the XS1100.
    Not the Pacifico bracket.
    Here's what the Vetter one looks like:
    And a link to the UK Parts Look up site:
    The 81's had a little bit of extra mounting locations for horns or the oil cooler I think:
    Here's a steal for a NOS on ebay: http://www.ebay.com/itm/Yamaha-XS110...tr#ht_45wt_965
    The Pacifico may fit with some slight modification to the mounting hole locations, but I'm not sure on this and others here may chime in on that.
    Here's what the Pacifico ones look like:
    80G (Green paint(PO idea))
    The Green Monster
    Got him in '04.
    bald tire & borrowing parts
    Scarlet
    Got her in '11
    Ready for the twisties!
    81H (previously CPMaynard's)
    Hugo
    Cold weather ride
    • sparkfly88
      • Mar 2013
      • 585
      • CedarKey FL
      Amazing find on that NOS mount!
      Really appreciate it! I purchased it.
      The one I was gonna buy was more expensive, and it was used. So really amazing find on that!
      I dunno about the wiring harness, as I haven't gone to get the fairing.
      I know I'll be getting a fairing, so I know the mount is the hard part to find. So I bought it.
      I think this set shall work nicely though for sure. I bet I'll go get it this afternoon or this weekend.
      79F
      "Excelsior"
      Hid headlight 6000k
      Stock jets
      Shinko 712 F & R
      TC fuse block
      Raptor 660 Acct
      • sparkfly88
        • Mar 2013
        • 585
        • CedarKey FL
        79F
        "Excelsior"
        Hid headlight 6000k
        Stock jets
        Shinko 712 F & R
        TC fuse block
        Raptor 660 Acct
        • GLoweVA
          • Jun 2011
          • 1957
          Looks like they should clean up nicely.
          That's a WJ 5 (IV). I like the vents, wish I had some in mine, but then again it doesn't get as hot here in VA as it does down there.
          See if you can get the key for that locking right side, if not, you can turn it with a large screwdriver to get it open and replaced with lock from Home Depot ($3)
          If that left side pocket cover is what I think it is, you'll like the pocket in a pocket.
          I'll look in my shed to see if I have an extra harness, just in case.
          The Green Monster
          Got him in '04.
          Scarlet
          Got her in '11
          Hugo
          Cold weather ride
            Aircraft window vents are much cheaper (and basically the same) than the actual Vetter vents.
            • sparkfly88
              • Mar 2013
              • 585
              • CedarKey FL
              Should I try to hunt down lowers for it as well?
              79F
              "Excelsior"
              Hid headlight 6000k
              Stock jets
              Shinko 712 F & R
              TC fuse block
              Raptor 660 Acct
              • sparkfly88
                • Mar 2013
                • 585
                • CedarKey FL
                All the keys are there, I asked about the wiring, he's gonna call me back in a bit when he takes a look at it.
                79F
                "Excelsior"
                Hid headlight 6000k
                Stock jets
                Shinko 712 F & R
                TC fuse block
                Raptor 660 Acct
                  That is totally your own preference.
                  • sparkfly88
                    • Mar 2013
                    • 585
                    • CedarKey FL
                    I just know there is tons of variations of lowers... Correct?
                    79F
                    "Excelsior"
                    Hid headlight 6000k
                    Stock jets
                    Shinko 712 F & R
                    TC fuse block
                    Raptor 660 Acct
                      Yup, I think the ones for the 5 are the hardest to find. Go to Vetters website and he lists the lowers and the types that fit which.
                      • sparkfly88
                        • Mar 2013
                        • 585
                        • CedarKey FL
                        About Vetter fairings: Vetter Corporation made Windjammer and Vindicator fairings. In addition, the company made fairings for Kawasaki which were essentially Vindicator fairings. All these fairings accept the same windshield, the same lowers and will fit on any Vetter hardware.
                        All Windjammer/ Vindicator/ Kawasaki fairings were the essentially same... only the hardware was different for different bikes
                        So, the lowers are all universal
                        Nevermind, as I scrolled down, I found the lowers section
                        79F
                        "Excelsior"
                        Hid headlight 6000k
                        Stock jets
                        Shinko 712 F & R
                        TC fuse block
                        Raptor 660 Acct
                          IIRC, the Vetter IV had a flat section above headlight that was straight going across lower section of shield, and it DID use a bit different lowers as mounting holes and curve were different.. 52 series lowers and several others will fit that Windjammer fairing, just some were cut back more to clear cyl. fins than others on smaller cc bikes.
                          • sparkfly88
                            • Mar 2013
                            • 585
                            • CedarKey FL
                            Well, even though I told the guy I'd go get Em, I think he sold Em out from under me.
                            Pretty irritated.
                            At least I will have the mount.
                            The front fairing is the main thing I want.
                            79F
                            "Excelsior"
                            Hid headlight 6000k
                            Stock jets
                            Shinko 712 F & R
                            TC fuse block
                            Raptor 660 Acct
                            • sparkfly88
                              • Mar 2013
                              • 585
                              • CedarKey FL
                              Mount came today. Along with the instructions.
                              It's funny how it's held on by two bolts, and two hose clamps... What a silly system.
                              79F
                              "Excelsior"
                              Hid headlight 6000k
                              Stock jets
                              Shinko 712 F & R
                              TC fuse block
                              Raptor 660 Acct
