Standard Tank wanted!
  • Surge 58
    • Jun 2013
    • 28
    • Cairo, New York
    Hello,
    Anybody have a decent standard tank that they want to sell? I just picked up a $25 standard tank that I was starting to work on and the darn top portion of the fill area came loose from the tank while I was working on it.
    Stephen-Catskills
    1980 XS1100SG
    Raptor 660 ACCT, Kerker turnout exhaust, progressive fork springs, Showa shocks and Tkat forkbrace.
    Previous ride.
    1982 XJ650 SOLD!
    What do you mean "came loose"? Pics help.
    • Surge 58
      • Jun 2013
      • 28
      • Cairo, New York
      The part that is attached to the tank where the gas goes in came loose from the tank. It happened when I was trying to get out a broken screw and was pushing down when it let loose.
      Stephen-Catskills
      1980 XS1100SG
      Previous ride.
      1982 XJ650 SOLD!
        If everything is still intact but the fill ring came loose just solder it back into place.
        • Surge 58
          • Jun 2013
          • 28
          • Cairo, New York
          Hi Nathan,
          So, if I solder it woud I use the same kind of solder used on copper pipes? If not what kind. The area around the tank seems pretty solid as well as the ring so a little bit of cleaning it up and sanding some would smooth it all out and seem very fixable. I tried saving this tank from this guy who would have let it sit in his old garage and rust some more. The tank itself has a couple little dents that I can tap out. The other challenge is trying to clean up the rust o the inside. I have already taken everything off of the tank including the taps which are stuck. I will probably have to soak them and then get rebuid kits for them. Anyway thank you for your advise and I do have a picture of the tank but have not yet figured out on how to post it.
          Thanks.
          Stephen-Catskills
          1980 XS1100SG
          Previous ride.
          1982 XJ650 SOLD!
          • Surge 58
            • Jun 2013
            • 28
            • Cairo, New York
            [/IMG]
            Stephen-Catskills
            1980 XS1100SG
            Previous ride.
            1982 XJ650 SOLD!
              Pictures need to be uploaded to a site like photobucket and then you post the provided IMG link in the text of your reply.
              Use a non lead, flux based solder. Do not use an acid based solder.
              • Surge 58
                • Jun 2013
                • 28
                • Cairo, New York
                Thanks Nate,
                I signed up on Photobucket and will have figure out how to use it. I will try sending a test photo next time before I send it here.
                Stephen-Catskills
                1980 XS1100SG
                Previous ride.
                1982 XJ650 SOLD!
                  • 8928
                  Copy the IMG link of your photo that you uploaded to photobucket and paste it here in your post.
                    Originally posted by Surge 58
                    Hello,
                    Hi Steve,
                    also check the drain tube that starts in the tank's filler cap pocket and exits at the tank's left rear. If it's blocked, no biggie. If it's rusted through inside the tank fuel can leak out of the drain tube and onto the floor.
                    Prepare yourself that your $25 bargain may not be as sweet as you hoped.
                    OTOH, in the past a Standard tank's filler cap and fuel taps alone have sold for more than $25.
                    • ViperRon
                      • Feb 2011
                      • 1062
                      • Woodstock, VA
                      Now this may be obvious to you but make sure to clean the fuel out of the tank. Heat tends to build up fumes and gas vapor can explode very easily. If the tank is very rusty gas residue can get trapped in rust pockets and heat will release it. So if the tank looks scally inside or has a lot of residue in the bottom clean it out first. It does not take a large explosion to bend that tank out of shape. Its just one more precaution to take.
                      Rodan
                      1980 G Silverbird
                      1198 Overbore kit
                      Grizzly 660 ACCT
                      Barnett Clutch Springs
                      R1 Clutch Fiber Plates
                      122.5 Main Jets
                      ACCT Mod
                      Mac 4-2 Flare Tips
                      Antivibe Bar ends
                      Rear trunk add-on
                        As to Fred's comments: yeah check the tube. If it is busted or has holes in it, solder the top hole and the bottom hole shut while your at it. Then if you ever get any water or gas in the recess in the top you need to soak it up and clean it out on your own.
                        As to ViperRon'a comments: absolutly clean it out first, you may find that there is no point in soldering the ring back in......
                        • Surge 58
                          • Jun 2013
                          • 28
                          • Cairo, New York
                          Howdy,
                          OK, I think that I might be able to post a picture. The inside is rusted so I will try cleaning up a bit before I spend anymore time or money on it. It does however seem pretty solid underneath.
                          Stephen-Catskills
                          1980 XS1100SG
                          Previous ride.
                          1982 XJ650 SOLD!
                            Dang! I thought you were just talking about the fill ring in the middle, not the whole recessed cap area!
                            Interesting!
                              Howdy, OK, I think that I might be able to post a picture. The inside is rusted so I will try cleaning up a bit before I spend anymore time or money on it. It does however seem pretty solid underneath.
                              Hi Steve,
                              ooh, that looks nasty but it does give you the opportunity to rip the cap recess & drain tube right out of there, weld in a sheetmetal patch and fit your choice of one of these:-
                              in it's place.
                              But first, use the search feature to find how to de-rust that tank with a battery charger and a box of WASHING soda. Not baking soda, that's a different stuff and won't work
                              Best you don't throw money and effort into a cap fix until after you have checked that the de-rusted tank is sound enough to work with.
                              The first clue is if the tank acts like a watering can when you pour the washing soda electrolyte in.
