Use whatever chassis you get cheap and has room for your powerplant. Any large bike frame will do considering the low power output of the diesel. Your main concern is going to be fitting the engine in the frame. Converting an XS11 swing arm to chain drive is nothing compared to the rest of the project.
An early wing would be interesting but you'd have to use a Beemer or Guzzi gearbox. Ask me off line about the 6 & 8 speed belt drive transmissions I designed.
You're going to end up with a big stinky bike that is slower than a flat head Harley but you're going to be the only one for a long ways around that has one.
Tony
Tony
The only ones that stink are the badly adjusted ones and those don't stink more than any other badly adjusted gas engine. Where I work we have a very large old truck that has an equally large v8 gas engine and it has a carburator. That thing stinks more than any of the 25 diesel trucks I have in the yard. Diesels that burn all their fuel in the cylinder and not in the pipes will not smoke, nor will they stink.
