I just started riding last year. Well, last year I rode over about a half mile of milled pavement and it sucked. I stayed pretty relaxed but I still didn't like it. We have a bridge here in Thurmond that is the metal grate and it felt the same. Well, now on my way to work there is about a 4-5 mile section of rode they have milled. Its a 4 lane highway and they have actually done the other side too. Anyone have any tips on this or what to watch out for. I haven't ridden to work yet cause I don't want to ride that far on the milled stuff, and it has rained every day. I am sure I would be alright, just would like to know what you guys think about it. I know to just relax and keep a good hold on the handlebars. It feels squirrely but I guess it should stay upright as long as I don't make any sudden movements and make the wheels slip, shouldn't it? Just thought maybe there were some tips out there.
Milled pavement
Yeah Jeff, I know EXACTLY what that's like. I hate the draw bridge and milled roads.
The XS11 is heavy enough and has enough stability to hang fine, but it still feels weird. Kinda of like it want to do what it wants to do regardless of where I want the bike to go.
You're right. just relax and let it ride thru it.Hi, my name is George & I'm a twisty addict!
80G (Green paint(PO idea))
The Green Monster
Got him in '04.
bald tire & borrowing parts
Scarlet
Got her in '11
Ready for the twisties!
81H (previously CPMaynard's)
Hugo
Cold weather ride
Its our skinny front tires that tend to get squirrely on that grooved pavement.
If we had 120+ size tires its less an issue.
You have right idea. Just keep it relaxed. Airing down a few psi to increase contact patch size may help.
JohnJohn is in an anonymous city with an Alamo (N29.519227,W-98.678980)
'81 XS1100H - "Enterprise"
There is a bridge over the river here in Cincinnati that is metal grate, and there used to be another one like it not far from my house. A 750 is not any better on those bridges than the XS11. Two ideas I use, one relax grip, two hit the throttle so I get over it faster, less time to suck the seat up my crack!!Life is what happens while your planning everything else!
Originally posted by jwhughes3 View PostIts our skinny front tires that tend to get squirrely on that grooved pavement.
John81H Venturer1100 "The Bentley" (on steroids) 97 Yamaha YZ250(age reducer) 92 Honda ST1100 "Twisty"(touring rocket) Age is relative to the number of seconds counted 'airing' out an 85ft. table-top.
I don't have any issued with that pavement, but the metal grate bridges then it gets a little squirly.Nathan
One other thing that contributes to front end weaving is worn/loose bearings.
I don't like ball bearings as wheel bearings since you can't take the radial play out of them. However, they are what Mamma Yamma gave us, so the best we can do is replace them with the best quality bearings we can get, and keep them clean and lubed well.
CZ
Originally posted by jjz28 View PostWhat tires you run nate? My bike wonders all over the place.Nathan
Keep your tire presure up. A tire that is low will have more tendency to follow the grooves. Another issue is what type of surface the grooves are in. I know from experience concrete grooved pavement will grind the tread off so do not be suprized if you do not get good tire wear. I imagine that the surface with sea shells mixed is just as abrasive. Slower speed seems to make it more noticable but also higher speeds will cause more wear on tires.
Your benifit on the road is it gives more grip and control to cars and trucks in the rain and they are the biggest danger.To fix the problem one should not make more assumptions than the minimum needed.
Rodan
1980 G Silverbird
1198 Overbore kit
Grizzly 660 ACCT
Barnett Clutch Springs
R1 Clutch Fiber Plates
122.5 Main Jets
ACCT Mod
Mac 4-2 Flare Tips
Antivibe Bar ends
Rear trunk add-on
