I was at harbor freight tools the other day when i came across this lift for motorcycles. you can see it at harbor freight tools.com. some where on their site you can type in lot no.2792. right now it's selling for 59.99. they also have other tools very reasonable. many can be used on our rides. looks like same lift everyone else is sellin gfor 100-200 bucks.
motorcycle lift
motorcycle lift
when you want something bad enough, don't let anything stand in your way, and don't take "no" for an answer. EVER
graybird78
80 sg (old faithfull)Tags: None -
Re: motorcycle lift
The problem is that you have to take your pipes off to use it.Originally posted by graybird78
GeezerHi my name is Tony and I'm a bikeoholic.
The old gray biker ain't what he used to be. -
re lift
wouldn't it be possible to use some thick foam or something else to protect the pipes from damage. looks like it would work for those repairs that require removal of exhaust?when you want something bad enough, don't let anything stand in your way, and don't take "no" for an answer. EVER
graybird78
80 sg (old faithfull)Comment
Since the lift has a capacity of 1500 lbs. (I bought one) and it has a problem of hitting things on the underside of our bikes, I've considered mounting a platform to roll the bike onto and raise it like a table. Yes, I would make sure it is stabilized, maybe some outriggers or something. Still just an idea rolling around in my head.Pat Kelly
<p-lkelly@sbcglobal.net>
1978 XS1100E (The Force)
1980 XS1100LG (The Dark Side)
1999 Suburban (The Ship)
1994 Dodge Spirit (Son #1)
1968 F100 (Valentine)
"No one is totally useless. They can always be used as a bad example"Comment
Re: re lift
You'd risk ripping the exhaust studs out of the head.Originally posted by graybird78
The old gray biker ain't what he used to be.Comment
I've seen some lifting tables on eBay in the $300 range. I asked the sellers and they all said the tables were made in China. It's only a matter of time before Harbor Freight or other cheapo tool dealers have them locally for less money. I wouldn't be surprised if they turn up at Costco, they have the other style lift.Originally posted by Pat Kelly
hi guys
if you look at my post titled table lift
you will see a lift I built from a picture on the internet
and it works real nice
don't know the capicaty but it lifts my xs
and it cost less than 200 dollars to build
and that was buying, all brand new steel
little more time at the scrap yard and less money spent
and it brings the bike up to 34 inches highhttp://home.securespeed.us/~xswilly/
78E main ride, since birth the "good"
78E Parts, the "bad" fixing up now
78E Parts the "ugly" maybe next year
79F Parts
80G Parts
75 DT 400B enduroComment
I have the plans but I don't think I'm up to building one.Originally posted by xswilly
hi guys
A couple of strategly placed blocks would solve the exhaust problem. i use a floor jack on mine couple blocks under frame does the trick. Just a thought.1982 XJ 1100
now in the stable. 1982 xj11, 18,000milesComment
There's nothing like a lifting table for working on bikes. I once worked in a shop that had 3 car lifts converted for motorcycles. I could lift a bike 5 feet up. Most of the time 30 or so inches is good enough but lifting it way up made oil changes much easier.Originally posted by chevy45412001
