Name my Bike
  • donebysunday
    • Oct 2012
    • 1737
    • New Berlin, Wi.
    Name my Bike
    My 81 LH seems to be an aim and pull the trigger under FWO. Looking for air pressure on the front forks and settings for 400 LBs. load. I seem to remember 7 LB. front forks and full adjustment on the rear.
    I'm also looking for a name I'm thinking, Midas, Magnum, Apollo, Hip Shooter ?
    Here ARE SOME PICS
    http://tinyurl.com/d7beztr
    http://tinyurl.com/cjuhbxu
    http://tinyurl.com/c439w6l
    76 XS650 C ROADSTER
    80 XS650 G Special II
    https://ibb.co/album/icbGgF
    80 XS 1100 SG
    81 XS 1100LH/SH DARKHORSE
    https://tinyurl.com/k6nzvtw
    AKA; Don'e, UD, Unca Don'e
    • 3180
    To me a bike will find it's own name. My 81LH is named TLC after it's heritage....THE LEARNING CURVE. I had to spend more, do more, research more, wait longer for stuff, Delve deeper into a bike than ever before.
    It will name itself if you let it. What do you describe it as to your friends? When you say to the wife I am taking (insert name here) out for a run, what do you call it.
    As for the air pressure, put some in. Then ride it a bit and see if you like the ride. Go from there till it handles the way you like it. No hard and fast pressure settings to go by. IIRC the manuals differ on max and min pressures.
      - - - I'm also looking for a name I'm thinking, Midas, Magnum, Apollo, Hip Shooter ? - - -
      Hi Don,
      CHARYBDIS
      because of the swirly wheels and like any XS11, because it's a legendary monster.
      • h311rasor
        • Feb 2013
        • 5
        • Richardson, Tx.
        you need to go with the LONE RANGer theme ... and name it TRIGGER
        79 Cafe
