I want to broaden my knowledge
  • GLoweVA
    • Jun 2011
    • 1957
    • Virginia Beach, VA.
    Alright, somebody please school me,
    I thought the (78-82) XS11/XJ11 were the only 4 cylinder bikes of the yamaha era, but I just saw a pic of an XJ650 that is also a 4 banger.
    What other Yamahas of this time frame (78-84ish) are in-line 4's?
    Has anyone looked at wether the header pipes from these other in line 4's will fit or not?
    80G (Green paint(PO idea))
    The Green Monster
    Got him in '04.
    bald tire & borrowing parts
    Scarlet
    Got her in '11
    Ready for the twisties!
    81H (previously CPMaynard's)
    Hugo
    Cold weather ride
    all the XJ models were 4 cylinders and then the XS11s
    • GLoweVA
      • Jun 2011
      • 1957
      Aren't the xj650s twins?
      The Green Monster
      Got him in '04.
      Scarlet
      Got her in '11
      Hugo
      Cold weather ride
      • GLoweVA
        • Jun 2011
        • 1957
        Oops I supposed I errored there. The xs650s are twins.
        The Green Monster
        Got him in '04.
        Scarlet
        Got her in '11
        Hugo
        Cold weather ride
        • Cuda 69
          • Jan 2012
          • 676
          • Greenwich N.Y.
          xj 650 was a 4 cyl.I had one,they called it a maxim.550's were also 4 cyl.I do believe they made a 750 maxim 4 cyl.too.
          FOXS-XS11SG
          1980 XS11SG-sold
          1999 Vulcan classic-sold
          1982 XJ 650-sold
            Right you are Nate, but that statement could make one believe that the XS's came after the XJ's. Yep, after Yamaha's success with the 750 triples and then the XS11's quad, they found success with the 4's and made several smaller engine versions...the 550 and 650 and 750's for 82, 83, but dropped them all in 84 for the FJ 600 and 1100, and the Virago V-twin series!
              I see your point TC. I did not mean my phrasing in a chronological time sense, I should have used "also" rather than "then".
              • rpgoerlich
                • Dec 2007
                • 643
                • Katy, Tx
                Had quite a few of the XJ's myself.
                The XJ650 came in 1980
                The XJ550 came in 81
                The XJ750 came in 81
                Richard
                  In the same time period SECA used the "same" inline 4 as the Maxim.
                  • b.walker5
                    • Feb 2009
                    • 1745
                    • Invercargill, New Zealand
                    Not quite correct TC. The XJ600/900 went from 83 to 94, then came the Diversion inline 4, and the XJR came along in 90, first in a 400, and then 1200 in 95, and 1300 shortly after until present day. Also in the middle was the YX600 Radian, from 86 until 90, and the FZ. The Radian motor was initially designed for the XJ550, and pretty much all of the above engines are based around the original XS/XJ design, with the only real departure being the XJ diversion series which used an inclined cylinder as apposed to the more vertical design of the others.
                    • GLoweVA
                      • Jun 2011
                      • 1957
                      Cool. So, the XJ line from 82ish on up are all 4 bangers.
                      The earlier ones were MAXIMs and also SECAs then came the Diversions and the XJRs.
                      Whereas, on the later ones, the engines started slanting forward more and the bike transitioned from a cruiser to a sport bike ride.
                      Basically I was asking to better understand what's out there.
                      I so much love the in-line 4 on my G and SG and wanted to look for another older yammy cruiser type that was also an inline 4 too.
                      Thanks guys.
                      The Green Monster
                      Got him in '04.
                      Scarlet
                      Got her in '11
                      Hugo
                      Cold weather ride
                        • 2095
                        Here's a pic...
                        ...of my '83 XJ750 Mid. Max. , which is a quick, little, good around the town go getter or a one up criuser, but the brakes, dual disc in front and drum and shoes in the rear, are not that great trying to stop a 400 plus lb. bike two up. One good point is the valve shims are the 29mm, so I adjusted both the XS11 and XJ 750 at the same time, allowing me to swap shims between the two
                        The XJ 750 is the little brother to the XJ 1100.
                        Although the charging system mimics the Elevens , I do like how Yamaha put the gen/alt up behind the jugs on the XJ 750, making a narrower profile
                        Day I brought it home
                        And semi-restored
                        I did a quick check on the O.D. of the stock down tubes of both the XS11 @ 37.75 mm and XJ 750 @ 37.50 mm , so they're close but I'd have to pull the pipes off of the XJ 750 to see if the head, which I beleive, is smaller than the XS11's
                        Maybe someone has a head from a XJ 750 in their stash they can measure.
                        Now I'm curious also, I may just loosen number one on the XJ 750 and test fit the XS11's down pipe
                          • 2095
                          Downtube Comparison
                          GLoweVA, your query has sparked my interest and curiosity so I did some comparing between my XJ 750 & XS11 downtubes.
                          XJ 750 on top of XS11
                          Head side - XJ 750 on top
                          XJ 750 flange too small for XS11 head
                          XJ 750 pipe on XS11 head with XS11 flange ( pipe is a little loose radially )
                          side veiw of XJ 750 pipe on '80G
                          side veiw of XS11 pipe on '80G
                          XS11 muffler end
                          XJ 750 muffler end
                          XS11 head end
                          XJ 750 head end
                          I beleive one could make the XJ pipes work if absolutely necessary but IMHO the smaller pipes will radically inhibit the flow creating higher exhaust valve temps.
                          I wonder if these would work:
                          http://www.ebay.com/itm/YAMAHA-FJ110...cd431c&vxp=mtr
