Well, winter is soon upon us, and so the time has come to begin a new project. As luck would have it, a local XSive decided it was time to move on to an alternative mode of transportation and relive his garage of the XS11 it has been storing untouched for a couple of years now. I, of course, could not turn a blind eye to that type of neglect and torture of the sacred beast. And so we reached mutually agreeable terms for me to rescue the SG!
Now, as the old saying goes, it did not happen unless there are pictures…..
Front view of the bike, fresh off the trailer..
Right side view.. The side covers came with it, though they do need some paint.
Left side, this side cover is missing the tab, but has a block of wood attached to screw it into..rather creative I thought…
And the rear view, Notice the black bag under the rack. Due to this bag, the tail light was moved in almost the same spot as the 78-79 models…
Now for the ugly….the tank has a few dents, one looks to be the real killer requiring a replacement tank..
This one shows the deep dent that includes the gas filler area...
So I removed the bag and moved the light back into stock location, in the process discovering a broken piece, not sure how this got broken.…
As luck would have it though, that is one of the remaining items from my wrecked bike, so, easy no cost solution, replace with a good part. And here is the back view now…
The seat has a tear in it, so a replacement cover will be needed…
The exhaust is a Kerker 4-1. I was advised going in that it needs a baffle, the existing is falling apart. When I pulled the muffler off, I found part of the internals trying to fall out the inlet, notice the piece in two different positions in the pictures ..…
Now, I belive the internals slide out of these, I pulled the retaining screw at the outside bottom near the outlet, but it does not seem to budge, it has a couple dents, but I did not think they would keep it from sliding out, not sure what the screw on the inside is for…….
In the process of checking out the exhaust, I noticed the rear brake dragging badly since I tried to use it. Which led to disassembly of the rear brake system for cleaning. I also noticed I am consistent in getting bikes with a cracked rotor…
Rear brake system coming apart...
One of the main reasons the bike sat was the owner could not get the carbs to tune correctly. The 4-1 with POD filters needed some alternative jetting. I also found the floats are set pretty high. Main jets are up to 137.5 on the 80 model carbs, with 45 pilots. Have not measured the floats height yet, but I have all the jets and brass parts soaking in carb dip for the evening.
So, it appears I will have a few things to do over the winter.
So what REALLY happened that July day on I-74 was that when these petcocks were in the ON position by the handles and marking plates, they were feeding from the center port of the petcock to the ON nipple of the petcock. To the uninformed, the ON position is supposed to feed from the upper hole in the petcock to the On or rear nipple. the center hole feeds the Reserve and Prime ports.
