Hey Folks,
I got a little Poulan Woodshark 14" home/hobby chainsaw several years ago, and had taken decent care of it, would start fairly easily and run strong for many minutes at full rpm cutting some large tree sections and such just fine.
THEN the B-I-L loaned it out to one of his friends who used to work on a tree surgeon service! The borrower said he only used it on firewood... yeah right!
Anyways, got it back and the primer bulb was bad, replaced it, and some fuel line, got it to run, but would not run at full rpm for more than a minute before it would act like it was running out fuel! Knowing how finicky OUR bikes/carbs are, and this thing also has a carb, I ordered a carb kit for it, pulled it apart, NO float, just a spring loaded needle valve assembly, some fancy membranes that I think act like reed valves, as well as a rubber type fuel PUMP diaphragm, also the fuel inlet steel mesh screen. Put it all back together.
Still same symptoms, but also noticed that the prime bulb seemed much harder to push in. Swapped the 2 fuel lines going to the carb...1 from the bulb, and 1 from the tank, and it seemed like it behaved a little better. I then pulled the FILTER off of the end of the fuel line just in case the filter might have been a little clogged( although I did test blow thru it, wasn't breezy easy to blow thru, but I could?). The Engine would still run at full throttle for 30 seconds or so, but then when I would back off and try to give it just modest throttle, it would sound like it was running out of fuel again and die!
A friend of mine said that these consumer type devices were only built to last a short while....that the last 2 numbers of the model # would indicate the estimated # of hours it could be expected to run?? Mine is a 1950, so theoretically that's only 50 hours???
Question#1, anybody hear that hours lifetime description, or urban myth?
Question#2, My friend also said that worn rings will give similar symptoms, ie. hard to start, won't run very long etc.? This engine is a 2 stroke, any other suggestions of what I can do diagnostics wise to try to get it to run and keep running? I had the air filter OFF during the above tests so I could see the clear fuel lines, see if they were flowing or getting bubble/air locked, etc.!
Thanks in advance! I'm trying to get this thing both ready for possible use after SANDY's rath, as well as wanting to do some chainsaw sculpturing on the remnants of the 15 y/o will stump I had to pull due to root rot and breakage, leaning of tree over driveway!
