if the name fits
  • slow mo
    • 858
    • ontario canada
    if the name fits
    hi all !! i built a shed for my bike 7 month,s ago ,,,THEN i had a sidecar installed and surprise it might not fit in the shed,,no reply,s are necessary ride safe ,,slow mo!
    The Belfast Express {1980 xs11oo special/TC fuse box/mikes xs pods/bad boy horn!/mikes green coils/mac 4 into 2 exhaust/ standard bars/vetter fairing c/w ipod CD iphone am/fm radio/tkat fork brace ,,,tuned by tinman
    moemcnally@hotmail.com
    i AM THE KING OF NOTHING
    the people here are great , doesn't matter about the bike really/hamjam ////
  • CaptonZap
    • Jun 2010
    • 1748
    • Denver
    Originally posted by slow mo
    hi all !! I built a shed for my bike 7 month,s ago ,,,then i had a sidecar installed and surprise it might not fit in the shed,,no reply,s are necessary ride safe ,,slow mo!
    lol, pppppp cz
      Hi Mo,
      you are not alone. Way back I bought a total bargain sheetmetal shed kit from a friend who'd moved into a house with a garage before he'd gotten around to assembling the kit.
      Got it all assembled onto a treated wood base to find it was too short to close the doors on the bike unless I took the luggage rack off and put the bike in kittycornered.
      Is yours a sheetmetal prefab shed?
      Those are FNI to jumboize, sell it off and buy a bigger one.
      Wooden shed? Mr Skilsaw can be your friend.
        I know the feeling Mo. I build furniture in my basement wood shop. Made a full height entertainment center for my mothers house. Yeah, it was VERY interesting getting out of the basement.
        • slow mo
          • 858
          • ontario canada
          my shed is board and batten with 2 barn doors in front my bike now with the sidecar is a couple of inches larger that the door opening[Wide] maybe i can negotiate it in not really sure ,,i will try this weekend and report back as always ride safe ,,,slow mo!
          • tinman905
            • Aug 2007
            • 946
            • Orangeville,Ontario ,Canada
            Why are you parking it so early. You can ride that through most of the winter give or take a few weeks here or there. I see a couple of guys in the Orangeville Tim Horton doughnut shop every winter with their bikes with a side car.
            I think it would be a nice thrill spinning out in the snow with the sidecar on the bike. Put some chains on the tires and ride the snowmobile trails too
            BDF Special
              Hi slow mo,
              if the rig is only inches wider than the door opening it may be easier to modify the bike instead of jumboizing the shed.
              Put a 90º locking elbow joint in the handlebar's left side just by the 'bar clamp so the 'bar will go vertical to fit the rig through the doorway.
              And Tinman,
              Mo's motivation is likely the same as mine. I keep my rig in the garage year round so the seat don't get wet and the rig don't get vandalized.
              While southern Ontario's winter is not so severe as in the prairies, it still gets effin' cold out.
              My winter riding is limited to just a few degrees below freezing because that's when the bike won't start.
              And those bike tires skid like a bastard on icy streets so while a rig won't fall over on ice it will sail straight on with speed undiminished with the bars hard over and the brakes full on.
              • slow mo
                • 858
                • ontario canada
                hi ya Fred! due to being hit and run i suffered a brain injury that's making me lose the use of my hands so modification is a no go! but maybe by entering the shed straight on i can turn a bit inside the doors allowing the sidecar to enter as i said before once i have some help i will try? and let you know !! thank you as always for your sage advice!! ride safe ,,slow mo!!!
                  Hi SloMo,
                  As this is not an Electrical problem a large HAMMER should fix it
                  Happy to come by and "help" what is for lunch
                    Hi slow mo,
                    modding the bars was a daft idea anyhow. No matter how remote the possibility, having the bars fold up at speed is kinda scary to contemplate.
                    I suppose the shed doorway is narrower than the shed's wall to wall inside measurement by at least the thickness of the doorposts?
                    Moving the doorposts to the outside and putting gate hinges on the doors will give you another 7" of doorway width.
                    Must be someone around to swing the hammer for you?
                      Hi Fred,
                      Two good suggestions what to do with a sidecar in the winter
                      Hi Mo,
                      I could come and swing a hammer for you. The outside hinge idea sounds great if it gets you enough clearance. Otherwise a chain saw and extension might be in the sheds future
                      • mack
                        • 2411
                        • Ontario, Canada
                        Hi Mo
                        Cut the door/wall out large enough to provide easy drive in and then convert the hole onto a lift/drop ramp.You ever get that Octy replumbed.
                        mack
                        79 XS 1100 SF Special
                        HERMES
                        original owner
                        81 XS 1100 LH MNS
                        SPICA
                        78 XS 11E
                        IOTA
                        https://youtu.be/wB5Jfbp6SUc
                        https://youtu.be/RaI3WYHSuWA
                        Frankford, Ont, Canada
                        613-398-6186
                        • hamjam
                          • 1003
                          • Toronto ontario Canada
                          work party @ Mo's ok
                          what dates work?
                          Seamus Ó hUrmholtaigh
                          Niimi Moozhwaagan
                          NOTICE: No trees were destroyed in the sending of this message. We do concede, however, that a significant number of electrons may have been inconvenienced.
                          Any connection between your reality and mine is purely coincidental.
                          Member of "FOXS-11" (Former Owner of XS-11)
                          and SOXS
                          2008 Nomad "Deja Buick'
                          • xs11lover
                            • 1433
                            • Montoursville Pa
                            A friend of mine (not me ) redid his entire basement...new drywall, moodlighting, built-in tv center, carpet, shelves, paint, ect. Only to find that the turn halfway down the steps was too sharp to get a couch down there.......now a hole in the wall and a bulkhead will finish the new tv room.
                            79 XS11 Special (Lazarus)
                            79 DT 100
                            • slow mo
                              • 858
                              • ontario canada
                              --------------------------------------------------------------------------------- Great to hear from all of you!!!! Mack 1st job in the spring new lines! Phil and Hammer our combined ages almost 200 xslover thank you and Fred you are the sidecar man .. my brothers and i will wiggle this thing in ,,i wish i could post a pic but still don't know how ? thanks to all and ride safe ,,slow mo!
