For All That Don't Have A Torque Wrench
  • MPittma100
    • Aug 2011
    • 2359
    Torque Wrenches
    Yes they do have these same instructions with the ones that I have.
    MP
    1981 XS1100H Venturer
    K&N Air Filter
    ACCT
    Custom Paint by Deitz
    Geezer Rectifier/Regulator
    Stebel Nautilus Horn
    EBC Front Rotors
    Limie Accent Moves On In 2015
    Mike
    • latexeses
      • Jun 2008
      • 1491
      • California
      MPittma100
      Are your wrenches The "clicker" type?
      Everything on hold...
      • MPittma100
        • Aug 2011
        • 2359
        Clicker Type
        Yes, they are the clicker type. I have a total of 12 ranging from inch lbs to foot lbs and from 1/4 inch to 3/4 inch drives.
        MP
        K&N Air Filter
        ACCT
        EBC Front Rotors
        Mike
        • MPittma100
          • Aug 2011
          • 2359
          Clicker Type
          Within those wrenches there are 2 beam type for use where clickers will not work. An example would be setting/checking differential pinion bearing preload. Clicker type does not work for that.
          MP
          K&N Air Filter
          ACCT
          EBC Front Rotors
          Mike
            #35
            Actually, for setting bearing preloads what you want is a dial type wrench. Something like this: http://www.toolsource.com/drive-dial...-p-113706.html
            Much easier to read, and most have a 'memory' needle to show the highest torque reached.
            I've got a couple of torque wrenches that do inch-ounces for those really small fasteners...
            • MPittma100
              • Aug 2011
              • 2359
              Torque Wrenches
              I agree. I do have a couple of those in different ranges (low/high inch lbs).
              MP
              K&N Air Filter
              ACCT
              EBC Front Rotors
              Mike
              • latexeses
                • Jun 2008
                • 1491
                • California
                #37
                I had never read or heard about running a torque wrench through the range before using it to torque something.
                I can only guess but does anyone know exactly why running the wrench through the entire range of torque matters?
                "It seems I've been denied some critical, need to know, information".......
                • MPittma100
                  • Aug 2011
                  • 2359
                  Torque wrench settings
                  By running it through those settings you are actually keeping it calibrated. Similar to the process of torqing a head gasket whereas you don't torque it to its final amount the first time. You start out at a lesser amount and progressively (10-20 pound increments) work it to its final setting.
                  Different brand wrenches have different instructions. Some of mine tell you to back all the way off when not in use. Some others say to back off part of the way when not in use.
                  I know some of you have run in to the newer torque method called torque angle which is measured in degrees. Most all of the GM LS engines (and others) use these specs for engine repair/assembly. They give you a starting fastener torque in foot pounds and the final torque is a number of degrees of angle. And yes, that takes more special tools.
                  Yet another method of fastener torque is the bolt stretch method. Most all aftermarket high performance fastener manufacturers require this method over the foot pound method. Sometimes they will give the spec in either torque and/or stretch. This is most often used for connecting rod bolts. The makers put a centering hole in the head and the thread end of the bolts. This allows you to use the tool that centers in the two holes and has a dial indicator to measure the actual strectch of the bolt. Bolt makers say it is more accurate torque this way.
                  You also have different torque specs for the same fastener dependant on which type of thread lubricant that is used. Engine oil has a different torque spec than moly grease for the same bolt. Go figure.
                  MP
                  K&N Air Filter
                  ACCT
                  EBC Front Rotors
                  Mike
                  • latexeses
                    • Jun 2008
                    • 1491
                    • California
                    #39
                    MPittma100
                    I hunted around the web yesterday and the answer to the question of how to leave a torque wrench seems to spawn the "Whats the best tire" sort of debate.
                    Good information here. And I am not going to waste a chance to learn something.
                    Thanks everyone.
                    • je2wheeler
                      • Feb 2010
                      • 180
                      • Moved to NC to help my Dad
                      #40
                      Calibrated elbow
                      Once while torquing the head bolts on my '55 Nash flat head with my calibrated elbow, my Grand Dad said, "Just tighten the first bolt till it breaks, then don't tighten the rest so much." I'm fairly sure he was joking. That was '64 and I had not even seen a torque wrench. That old Nash went on for another two years.
                      1979 XS 1100 Special - Nicknamed "MONSTER"
                      ATC fuse box
                      Braded stainless brake lines
                      4/2 aftermarket exhaust(temp until stock is re-chromed )
                      V-Max auto cam chain adjuster
                      Brake light modulator with reserve brake light bypass
                      Vetter Windjammer III faring
                      Tkat Fork Brace
                      "Americans have the right and advantage of being armed; unlike the citizens of the countries whose governments are afraid to trust the people with arms”
                      James Madison, The Federalists Papers
                        • 3188
                        #41
                        Every torque wrench I ever had came with a calibration certificate looking paper and the instructions on care and use. It specified different things for different manufacturers. Here is a photo of the only instructions I have on hand and this was from a chinese cheapie I bought to tighten my clutch star nuts which ended up breaking the bolts. Do you think maybe I should have read them before using it. I now do
                        • CaptonZap
                          • Jun 2010
                          • 1748
                          • Denver
                          #42
                          Having watched some novice mechanics use a clicker wrench at a low setting, it should be mentioned, for those who do not have a lot of experience with these wrenches, that the "click", at low torque settings, is VERY subtle. It is easy to miss, if you have only used it at higher settings before.
                          Practice on a robust bolt first, to get the feel. FWIW CZ
