peacocks
  • halfbreed
    • Apr 2010
    • 31
    • Ohio
    peacocks
    hey there got another question if someone could answer?Do the xs1100 use the same peacocks as the xs750 ? i want to put manual ones from mikes xs store
    • 8074
    Halfbreed,
    What XS1100 do you have? Mike's late model XS650 petcocks will mount to the XS1100 standard tank.
    • Tat2demon
      • Jun 2012
      • 718
      • Sioux Falls, South Dakota
      I took the peacocks off my bike as soon as I got it. Feathers got in the way...
      Nate
      78 XS11 "Matilda" 2H7 000364
      K+N Air Filter
      88 Voyager XII
      81 XJ650 Maxim
        Yes, I hear they can cause chafing.
        We kid because we care Halfbreed....
        • rover
          • Jan 2004
          • 765
          • central WI (715)
          peacocks
          You are kidding? Gee, you don't look pregnant!
          79 F (Blueballs)
          79 SF (Redbutt)
          81 LH (organ donor)
          76 CB 750 (gone to MC heaven)
          rover has spoken
          • halfbreed
            • Apr 2010
            • 31
            • Ohio
            Iam sorry for not spell checking and being stupid.If one of the mods could fix my post .i havent been able to to find the edit button. I need to find out if them manual petcocks will work .thanks
              • 8074
              halfbreed,
              The XS1100 standard and XS1100 Special have completely different petcocks with different mount bolt spacing. We have to know what bike you have in order to answer your question.
              • jwhughes3
                • 2798
                • Home of the Alamo
                Hey its happened to all of us and it creates simple fun...
                Edit button is only there for a few minutes after posting, then its preserved forever! Cant edit now or none of the thread will make sense ( like it makes sense now!)
                Can you tell us which bike you have, Specal or Standard? Is tank more curvy or squarish? Standard squarish tank can use the manual petcocks from Mikes.net while Specials are harder to retrofit.
                John
                '81 XS1100H - "Enterprise"
                  • 8074
                  Parts-N-More has adapter plates for both tanks and a universal petcock.
                  http://www.partsnmore.com/parts/yamaha/xs1100/?filters[category]=carb&filters[fitting]=universal
                  If you have the old petcocks, you can rebuild them. If you do it right, they will likely last another 30 years. Here are instructions:
                  Rebuilding the Yamaha Vacuum Fuel Valve w/pics
                    Hi Halfbreed,
                    spellchecker is built in but it won't find a wrong word if it's spelled correctly.
                    FYI there's a bad language censor too.
                    It can be bypassed by mis-spelling (K replacing C) or by using asterisks (cl@d).
                    The edit button shows up next to the quote button at the bottom of your post when it's submitted.
                    You have all of 10 minutes to edit your post before the button stops working and fades away.
                    And yeah, Mikes taps will fit a Standard tank.
                    But they ain't cheap and some claim that Mikes rubber parts ain't of the best.
                    Try rebuild kits instead?
                    • halfbreed
                      • Apr 2010
                      • 31
                      • Ohio
                      Thanks for all the info about posting for future referance. I got a couple set of the mikes manual petcocks and was going to get rid of the vacum ones .I have used them years on my 750 with out problems. and yes it a standard tank ,not special.
                        • 8074
                        You need Mike's XS Part #20-0019. It's out of stock until the end of the year, according to the site.
