FIAM Horns are the BOMB!!
  • Cobia
    • Jul 2007
    • 1587
    • Palm Beach County, Fl
    My XJ came with them on and have been off for the better part of a year and a half. Now that I'm getting ready to sell it I took the horns off my G and put them on the J. I then installed the FIAMs on the G and went for a ride....
    You sure get noticed when you press the button. Well worth the electrical mod to make them work, relay and all.
    1980G Standard, Restored
    Kerker 4 - 1
    850 Rear End Mod
    Automatic CCT
    1980GH Special, Restored
    '82 XJ1100 (Sold)
  • trdriver71
    • 360
    • Edmonton Alberta
    Do you have pics and maybe a link for those horns?
    '79 XS11SF
    • Mathh
      • Nov 2006
      • 683
      • Beek, Netherlands
      Make sure you use a relais or they'll fry you're horn button spring. It may take a while, but it will happen.
      Cheers , math
      MV Agusta Brutale 910R '06.
      Yamaha MT-09 Tracer '15 grey.
      • Cobia
        • Jul 2007
        • 1587
        Math,
        I did use a relay, took a bit to figure out the correct wiring scheme but I got it.
        trdriver71,
        Here's a link to and Amazon sale. They have the kit for under $20. Mine are not red like these. Maybe they have other colors..
        http://www.amazon.com/FIAMM-74100-El...ds=fiamm+horns
        Kerker 4 - 1
        850 Rear End Mod
        Automatic CCT
        '82 XJ1100 (Sold)
          More tech info!
          From the www.fiamm.com site, more tech info on the 74100 horns:
          Twin Electric Horns
          This new electromagnetic horn was designed and engineered for automotive use for loud and harmonious sound. It was developed from the AM-80S and is available with dual configuration with chrome or red covers. It exceeds S.A.E. and O.E.M. specifications for a wide range of vehicle applications. Features steel housing with plastic cover and projectors. Copper wire coil motor. Each motor is tested to assure maximum performance.
          Cover Color
          Red
          Dimensions (L x W x D)
          3 7/8 x 3 3/4 x 3 1/2
          Min. Db Rating @ 4 inches
          130
          Power Source
          12V
          Frequency
          405-485
          Current Draw (AMPS)
          10
          Another photo from the Amazon ad. **Interesting....the above photo shows an oval/diamond shape, but the one below shows a rectangular shape to the opening of the horn??
          • Cobia
            • Jul 2007
            • 1587
            Strange about the shapes. Mine are more triangular.
            Kerker 4 - 1
            850 Rear End Mod
            Automatic CCT
            '82 XJ1100 (Sold)
            • pbaker27
              • Jun 2012
              • 108
              • Shakopee, Minn.
              That link only lets me select for a car. Am I missing something?
              Hydra'82 XJ1100 Frankenbike with a '79 engine
              ~dubbed "Hydra" by a friend, because "once one problem is fixed, another rears its ugly head!"
                Select Horns, Aftermarket, then NAFTA, and then scroll down the page some till you find the El Grande Twin, P/N 74100 to see them, but yes, they are mostly for cars, but these are SMALLER designed and draw much less amps than other horns of similar loudness. But as suggested above, would recommend the use of a RELAY that will have the power going directly from the battery thru the relay to the horns..the horn button will only need to carry the small power needed to trigger the relay!
                I had looked at air horns at Harbor Freight, but they were listed at 20+ amps draw!!!! The 10 amps is at the limit of the AUX fuse block slot on most bikes, so you will probably want to install a direct tap off the battery, but still install a ~15 amp inline fuse.
                • Cobia
                  • Jul 2007
                  • 1587
                  That's exactly what I did TC. Tapped off the battery with an inline fuse. I just wanted to get them operational. Next mod, later on, will be to tap into the main/switched power line and make them "switched" so they only operate when the ignition switch is turned on. Now they are hot all the time, meaning that they work even with the ignition switch turned off.
                  And you're right on the money, the horn button grounding only serves to trigger the relay.
                  You do need the relay for these to work on your bike.
                  They're LOUD as hell !!
                  Kerker 4 - 1
                  850 Rear End Mod
                  Automatic CCT
                  '82 XJ1100 (Sold)
                  • ManagerMike
                    • Mar 2010
                    • 445
                    • S.E. Michigan
                    Here's where I located my FIAMMs, used a relay and the aux fuse.
                    '78 E "Stormbringer"
                    • Cobia
                      • Jul 2007
                      • 1587
                      Mike,
                      That works !!
                      Kerker 4 - 1
                      850 Rear End Mod
                      Automatic CCT
                      '82 XJ1100 (Sold)
                      • Bassman
                        • Aug 2012
                        • 59
                        • Fort Collins, CO.
                        Quick question: the grill that goes over the front of the horn, what is it for? I have one FIAMM horn, but it doesn't have that grill. Is it necessary?
                        -Andrew
                        80 XS11 G: Project bike
                        • Cobia
                          • Jul 2007
                          • 1587
                          Bassman,
                          All I can think of for the purpose of the grill is to keep big bugs out of the throat of the horns !!!
                          My grills are off because I'd painted them gold top put them on the J, but now I'll paint them black for the G.
                          Pics to follow......
                          Kerker 4 - 1
                          850 Rear End Mod
                          Automatic CCT
                          '82 XJ1100 (Sold)
                          • Cobia
                            • Jul 2007
                            • 1587
                            Pictures of mine
                            Here's how mine look. They mounted right on the existing factory horn bracket.
                            https://
                            https://
                            http://
                            Nicely tucked in and don't contact the turn signals either at either end of the turning range.
                            Kerker 4 - 1
                            850 Rear End Mod
                            Automatic CCT
                            '82 XJ1100 (Sold)
                            • Bassman
                              • Aug 2012
                              • 59
                              • Fort Collins, CO.
                              Nice, those look sharp! I think I'll put mine in the same spot.
                              Anyone only run one or generally the pair?
                              -Andrew
