Hey folks,
Well, I'm looking to do another little project for my work. I need to make a little viewing type box, with special green filter, round dot diffuser screen, large viewing lens suspended above the box...so that I can hold eyeglasses between the view/ligth box and magnifying lens to be able to see the very fine/small laser etched markings on the lenses. There is a professional commercial grade device, but I'm trying to duplicate one.
I need/want to use 2 CFL type bulbs, the flat 2 pin 7 watt G23 style.
All of the compact electronic ballasts I'm finding say they can handle either 1 or 2 of the G24q type bulbs, which are 4 pin type bulbs but they have essentially 2 tubes vs. the G23 which is 2 pinned 1 tube bulb. They are also rated for at least 13 watt bulbs, not 7.
My questions are:
1) Is there a way I can run the wiring for a G24 ballast...1 4 pin style to drive two of the 2 pin G23 bulbs.
2) As long as the wattage rating of the ballast is higher than that of the bulb, is it okay to use a stronger wattage ballast on a weaker wattage bulb...I'm thinking it's okay because the lesser bulb will just draw less power from the ballast??
3) Some ballasts are designed to drive 2 4 pin bulbs. If I wire the 2 2-pin bulbs to 1 of the circuits, will the other be damaged or the ballast damaged?
My questions are:
I have learned that the smaller 2 pin bulbs have built in starters, so that they need to use the Magnetic ballast, not the electronic ones! The 4 pin bulbs need the ballast to provide the starter function, and so the electronic ones work for them.
