Hey there Folks,
Once again I come to the great trough of learning and beseech the masses to increase my knowledge base!
I first had a little pancake compressor, just a few gallons, then got an extra 10 gallon tank, but still didn't have the volume reserve to run the air tools I wanted to. I then got a 25 gallon system, supposed to get up to 120 psi, and flow IIRC 4-5 ft/sec. I have a good quality Goodyear 3/8" 50 foot long hose. I have 2 different 1/2" impact drivers wanting to use them for light duty like changing tires and such. However, it doesn't seem to have the ability to FLOW the volume needed to feed the drivers...I only get a few hits, 5-7 before it craps out, I have to wait for the pressure to build up in the line before using it again! While writing this I think I may have come up with the limiting factor being the regulator on it. I had it set/open to allow the maximum pressure, but I think it may not have large enough openings to allow the volume to flow as quickly as it needs to.
The Impact drivers actually stated that they should not be run at pressures over ~90 psi IIRC, but I can't recall the FPS rate they need, one is a basic HF unit, the other is a Campbell Hausfeld supposedly rated at like 250 ft/lbs torque.
Is the 3/8" line big enough to flow the volume of air these wrenches require or do I need to get 1/2"? I'm going to work with the regulator...it actually has 2 on there, one right on the tank, a second one that is part of a dehumidifier/oiler combo. I'm not using the oiler part.
Any other thoughts, suggestions, info would be appreciated.. ! I've been looking at possibly getting an ELECTRIC corded 110v 1/2" Impact Driver if I can't get these pneumatic ones to work. I could have sworn that the 25 gallon tank would have given me enough pressure/volume to drive these things!?
I can probably get one rated at a higher level, but I decided to try it with just that for now.
