Hey folks,
Okay, have a PITA job to do on my SUV! Timing belt change on a 2004 Xterra 3.3L V6. I have a service manual, and this engine doesn't use an auto timing belt tensioner....it uses a staticly set tensioner that they say does not need resetting once it's set for the life of the belt...~ 100K miles which it is now a little overdue, hence my need to chnage it.
However, the book says that I need to apply 22 lbs of tension/force against the belt between the 2 cam sprockets and measure the amount of deflection, should be ~0.50 inches. If it's more or less, I have to readjust the tensioner position.
MY question is HOW do I apply this measured amount of force? I don't have a fancy tool, or even a pull force gauge that I could rig up to the belt!
I have some weights that I use for lifting, I could place a 20 lb weight on the belt since a 20 lb weight is 20 lbs of downforce.
Any other suggestions?
The cam and crank marks were still aligned, but it took me a while to realize that they were only worried about the # of belt notches between the crank and the first and then second cam sprocket....but not on the slack/tensioner portion, and so the belt marks were not going to line up, at least not for the first several crank revs. I set the tension slack by hand trying not to get it too tight.
It's a shame they make it so hard to get to the adjuster, otherwise I'd check and set it at like 50k or so. I still can't believe they don't use an automatic or spring controlled one? There is a spring on the tensioner, but it's still LOCKED in place one you set the amount of tension! I guess they calculated that too much SPRING tension keeping it tight might cause the belt to stretch prematurely reducing the 100k range/durabilty it currently has!?
