fork brace
    • 9980
    fork brace
    Anyone know anything about this fork brace? I've only seen a couple and this one came off a set of forks from a smaller XS.
    It seems to work as it should. The only problems, it's a PITA to install and the brake hose brackets don't fit anymore.
    • 8877
    Yep, I've fooled with those before, just what you said, can't use the brake hose brackets anymore. I had to bend the brace slightly so it would not bind the forks with outward pressure, YMMV. Good brace though, does it's job.
      • 9980
      This one fit snug but I had no problem lining up the rotor slot on the right side (special).
      I've not ever run a brace and couldn't bring myself to toss Tkat a $100 for something I wasn't sure of.
      I like the way the front end feels now. Don't need to manhandle through corners anymore.
      I'm sold.
        • 8877
        I'm sold.
        For sure, night and day difference. The one I worked on was on a Standard, they will probably fit both.
        • tom clisham
          • Sep 2010
          • 627
          • Northern Illinois
          Xs650
          I think.................
          I've seen those on ebay as having come from an xs650.
          Very old school.. Looks kind of neat.
          Tom Clisham
          Age is relative YOU WON"T GET OLD TIL YOU SELL THE BIKE
          _____________________________________________
          '78xs1100E ,all stock & original GONE TO WISCONSIN
          '80 SG Vetter fairing,hard bags,trunk,fork brace,
          stock headers with fishtail mufflers,black & beautiful GONE TO ARIZONA
          79SF lowered,jardine 4/2 exhaust,pod filters,drilled rotors,fork brace, bar hopper
          79SF 1 owner,8000 miles, restoring to completely original ( I hope) GONE TO FRANCE
            • 9980
            The forks were smaller diameter tubes and had the smaller diameter rotors so I knew it was at least a 750-850 because it had a 19" wheel. I think the 650 had a smaller wheel. Didn't it?
            • jwhughes3
              • 2798
              • Home of the Alamo
              Wire spokes
              Didnt 650s have wire spoke wheels?
              I thought it must have been a 750 or 850 from the tapered front fender on it.
              Brace looks like it got a nice paintjob.
              John
              '81 XS1100H - "Enterprise"
                • 9980
                Yeah, the 650 did have spokes didn't it and that wheel was aluminum.
                I did strip it and paint it JW but I kinda intercoursed up the paint putting it on. GEEZE what a PITA.
                Not too bad though.
                Thanks brother.
                  FWIW, various years of XS650 had 3 or 4 different styles of wire-spoked wheels as well as the same pattern of 7-spoke cast wheels that are on the XS11.
                  All XS650s have 19" front wheels, any style of XS650 front wheel will bolt right onto an XS11.
                    • 8058
                    It's a XS650 brace. It will fit the XS11 just as easily as it does the XS650; especially the standard. The XS650 shares wheels with the XS11, and with the standard, it can share the front fender.
                    The downside to this brace is that it will add sticktion to the forks. It has to be carefully tweaked, as noted by BikerPhil. The TKAT and Tarozzi braces do not suffer from this.
                    • CaptonZap
                      • Jun 2010
                      • 1748
                      • Denver
                      Being a belt AND suspender kind of guy, I have one like that, and T-Kats type put on top. 80G. Since I never rode an 11 without one, I can't say what the improvement is.
                      My bike was a one owner, bought from the original owner, so I assume it was a dealer option, since the owner was a buy it and ride it type, as opposed to a "I'll put every accessary I can find on it" type.
                      The brake lines have what look like factory brackets holding them to the plate part of the brace. CZ
                        • 9980
                        The one I have has a lot bigger plate where the mount holes are as you can see in the pic.
                        Ok, I'll bite. What the heck is "sticktion" ? I didn't have to force any bolts, everything lined up perfectly.
                        • steelraider
                          • Jul 2011
                          • 55
                          • Spring City, TN
                          Forks are misaligned slightly not allowing telescoping action to occur smoothly causing them to stick slightly ! STICKTION!!!!!!!!!!!!!
                          Larry Walker
                          Ham Radio kw4a
                          ex Submarine Sailor (8 yrs)
                          Dirt Rider 1970-1980
                          Sreet Rider Touring 1980-2000
                          Couch Potato 2000-Present
                          1980 XS1100 Standard
                          1979 XS650 Special
                          2000 BMW R1150GS
                            • 9980
                            Well mine don't seem to be sticktioning at all so I guess I'll just ride.
                              • 8058
                              From Wikipedia:
                              Stiction is the static friction that needs to be overcome to enable relative motion of stationary objects in contact.[1] The term is a portmanteau of the term "static friction",[2] perhaps also influenced by the verb "stick".
                              Here is the link: STICTION
                              I spelled it wrong in my previous post.
                              All of the telescoping forks on our bikes suffer from stiction. The hoop brace can make it worse. I didn't say "will", I said "can". When you set your laden sag, you measure the difference between the forks after falling, and after rising. Taking the average accounts for stiction.
