Why does a lot of people wind up taking the centerstand off of these bikes? My xs1100 and xs750 have had the center stand taken off sometime in life and are not on there. Do they drag/scrape easy? How do people check the oil level without one? Anyone have one to sell?
Centerstand
There are a lot of aftermarket exhausts over the years that don't work with the centerstand. I've heard that the legs of the stand do scrape first when cornering, but that's not the case with my '81. Some, it may have just been a matter of aesthetics or decreasing the weight by a few pounds.
Even though I have a center stand, I just pick the bike up off the sidestand to about straight up, and hold it there while I look at the oil level? I see them on Ebay all the time, though someone might hook you up here cheaper.Try your hardest to be the kind of person your dog thinks you are.
I took mine off for aesthetics and to shave a few pounds, but I can slip the bolts through and have the bike on the stand at home in less than a minute. They're nice for oil level or cam chain tensioner work.1979 Yamaha XS1100SF (gone)
Airbox w/K&N element
Jardine 4 into 1
145 mains, 45 pilots
1996 Ducati 900SS CR
1977 Kawasaki KZ900-A5
1975 Honda CB550K
Originally posted by trbig View PostEven though I have a center stand, I just pick the bike up off the sidestand to about straight up, and hold it there while I look at the oil level
That's how we do it here too81 SH Something Special
79 SF MEAUQABEAUXS
81SH Nor'eas tah (Old Red)
80 LG Black Magic
78 E Standard Practice
James 3:17
“Alis Volat Propriis”
Yamaha XS 1100 Classic
For those on FB
Hi Jeff,
For checking the oil. I have a mirror on a stickDon't even have to get off to check the oil level
Addie does have a centre stand but i think some PO changed it for a shorter one so a real bitch to get on or off. Yes ! They do come in different lengths, if you are looking for a replacement.
Phil1981 XS1100 H Venturer ( Addie)
Originally posted by MaximPhil View Post...Addie does have a centre stand but i think some PO changed it for a shorter one so a real bitch to get on or off. Yes ! They do come in different lengths, if you are looking for a replacement.
PhilFast, Cheap, Reliable... Pick any two
I heard it has to be on the centerstand to get the oil level right, i dont know though cause i dont know how high it raises the back wheel and how that would affect the level. I check mine now just holding the bike straight up and if that is fine, i will continue to do that. I wouldnt even need a centerstand, I only wanted one if it was needed to check the oil right.Jeff
77 XS750 2D completely stock
Originally posted by crazy steve View PostNope, they're all the same length.... look here: http://www.xs11.com/forum/showthread.php?t=36551 for the differences...
Thanks for the picture and dimensions for stand. I have the 81H with 6 1/2 so apparently the correct stand. Any ideas why the bike has to be lifted 1 1/2 inches to get over the hump when putting on stand. I can not do it alone either on or off. Rear tire touches the ground when on the centre stand.
Shock length?
Is the shock length off an inch?
JohnJohn is in an anonymous city with an Alamo (N29.519227,W-98.678980)
'81 XS1100H - "Enterprise"
Phil81H Venturer1100 "The Bentley" (on steroids) 97 Yamaha YZ250(age reducer) 92 Honda ST1100 "Twisty"(touring rocket) Age is relative to the number of seconds counted 'airing' out an 85ft. table-top.
Originally posted by jjz28 View PostWhy does a lot of people wind up taking the centerstand off of these bikes? My xs1100 and xs750 have had the center stand taken off sometime in life and are not on there. Do they drag/scrape easy? How do people check the oil level without one? Anyone have one to sell?
I took mine off to use it's frame mounting points as two of my sidecar subframe attachment points.
Like my Special 'trees and gas tank, I'm keeping the stand in case I need to swap the bike back to solo use and original spec.
Except for the rototiller bars. Anyone wants those back on he can go find his own.Fred Hill, S'toon
PhilCy
Originally posted by cywelchjr View PostDepending on the rear tire I have on, the rear tire is anywhere from 1 1/2 to 4 inches above the ground on the center stand (with the closest I can get to the stock tire size in a S11 it's maybe an inch and a half, with the 130/70 17 the PO had on it it was about 4 inches above the ground). I'm guessing that with the original stock tire it was a little bit close to the ground, but not really much more).
I have an S11 on at the moment.
