So I bought a used pool pump from this guy and he installed it and told me he would warranty it for a year . I paid 300 in cash. The pump doesn't work and he is not responding to my calls or text .
I have the feeling im getting screwed
I agree
Lesson learned:
1. use plastic - you can always reverse the charge and let HIM fight with MC/Visa to get his money
2. dont buy used equipment on something its impossible to know how much its been used - pool pumps run all the time and hard to tell how used it is - new water pumps always worth money - I feel same on cars - never install anything but a new water pump.
3. pools are expensive - its one reason I dont have one anymore - I am cheap
Sorry you are having a tough run Garth - its karma for cornering the market on Rabid Transit fairings
JohnJohn is in an anonymous city with an Alamo (N29.519227,W-98.678980)
'81 XS1100H - "Enterprise"
"Not all treasure is silver and gold" -
81H Venturer1100 "The Bentley" (on steroids) 97 Yamaha YZ250(age reducer) 92 Honda ST1100 "Twisty"(touring rocket) Age is relative to the number of seconds counted 'airing' out an 85ft. table-top.Comment
I guess he needed a new pool pump Garth.Greg
The list changes.Comment
If it makes you feel any better, Vasoline is much cheaper than $300.Life is what happens while your planning everything else!
78 XS750Comment
Do you know where he lives?ROAD TRIP!!!. Sorry about your troubles,I hate dishonest people.
FOXS-XS11SG
1980 XS11SG-sold
1999 Vulcan classic-sold
1982 XJ 650-sold
Old is only a state of mind......JohnComment
that sucks
Hey Garth, I have a 1.5 hp pool pump mounted on a chunk of plywood that you can borrow, if you'd like. You need to keep circulating your pool water so the chemicals can keep the algae at bay. This one has a three foot cord with a plug, runs on 110v. Hell, you can even buy it off me for $300, and I'll guarantee it for a year!
scootComment
Suck it up.
That's only a one time thing and you coulda turned down the deal anyway.
The Government screws me out of more than that every effin' pension check.Fred Hill, S'toon
"The Flying Pumpkin"Comment
What is wrong??
Hey Garthmaster,,,,what is wrong with the pump? I ALSO have a pool and the pumps can act up, Is there no water flowing, does the motor spin, is there current going to the pump??? What is it doing? Give us some detail and maybe it is something simple...................or give me a call........Mike, North of youmike
1982 xj1100 maxim
1981 venture bagger
1999 Kawi Nomad 1500 greenie
1959 wifeComment
Not failiar with pool pumps, but alot of motors in that size have thermal overloads built into them. They will get hot if trying to do to much and the thermals will kick it off, once it cools down, it will kick back on.
If that is what is happening, then first check you do not have anything plugged up in your lines causing the pump to not be able to move the water through. Any valves you forgot to open?Life is what happens while your planning everything else!
78 XS750Comment
Do you have a bleeder valve near the pump? I've had pool pumps load up like that and die from the sudden introduction of load (water) to an air filled pipe, even on 4" pumps driven by 15HP. Try to bleed air out of the line as best you can, especially if you can force a garden hose into the line, force water through the strainer or overfill the pool to provide a self-priming condition.
Is this a self-priming system? Air lock or incorrectly bled lines can do funny things.
If you know the line is as bled as it can be try holding the 'on' switch down for 30sec-1min and see if it 'catches.' Or manually apply power somehow to make this happen. I have a touchy facility (Lowrey C Mounger) that airlocks super easy and no amount of bleeding will make that motor go until it's forced to run for up to 2 min. and bleed itself.
The only pumps I work with that are as small as I'm assuming yours is are vacuum systems or hot tubs, so I'm admittedly more used to dealing with much heavier duty commercial equipment that may handle a beating with more grace. Any specific info on pump/motor brand and your system would help. I'm also assuming this is a high-rate sand system or cartridge system as well, which can cause airlock more easily than a vacuum-grid system. Either way there needs to be a bleed valve on the pressure side.
Pools can be real fussy and each and every one is different no matter how exactly similar they may be.1990 Ninja ZX-10. It's the Silver Surfer. HI-YA!!
2006 Yamaha XT-225. Yep, I take it on the interstate. It's Blue Butt.
1982 Toyota 4x4. 22R Cammed, 38/38, 2" pipe, 20R head with OS valves, performance grind and other fun stuff. It's Blue RASPberry.
1969 Ford F-250 Camper Special resto project. 390 RV cam, Demon carb, Sanderson headers, 2 and a quarter pipes with Magnaflow mufflers. It's Blue Jay.Comment
I fixed it ! The idiot had it wired wrong . It is setup from the factory on 220 and there is ajumper with a spade on it that has to move over one spot . It even had a big Orange tag showing what to do .91 kwaka kz1000p
Stock
( Insert clever quote here )Comment
