My to-Do list
  • KA1J
    • 664
    • Groton, CT
    My to-Do list
    I had some time on my hands & was on the XJ11 so I thought I'd get all critical about what I'd like to make right and get the bike as clean as possible. I've done so much already to get it running right and now want it to be as clean as possible. So I took out my notebook & started writing down every little thing I saw that just didn't look right so I can fix it and check it off the list. A few things like replace the tach & tires were in the mental to-do list but now it's all on paper. Here's my to-do list to accomplish before July & There's probably some overlapping but this is my check list...
    XJ11 To do - Repair or Clean
    Bend Right tank badge to properly fit.
    Clean tachometer Wheel Assembly.
    Clean fins on R. Side of Head.
    De-rust Chrome on front axle bolt & Castle Nut.
    Clean Header Heat Sinks
    Apply whiteout to Instrument cluster recessed lettering.
    Adjust left handle controls to make horn button easier to get to.
    Add fuel filters to each side.
    Replace Schrader cap for left fork air line.
    Replace R. bolt holding Vetter to frame (compare to L side).
    Add plastic tube from Air Horn.
    Replace all three Brake Bleeders.
    De-rust and prep the insides of the fenders.
    Find out what the taped electrical connection is above R front reflector
    Replace the R. Muffler Gasket
    Clean and replace R muffler Clamp
    Replace front tire
    Replace rear tire
    Grease Axle Splines
    Replace missing bolt on backrest
    Replace license plate bolts.
    Clean and detail Vetter bags.
    Clean aluminum on rear shocks.
    Clean instrument panel & Ignition key cover; use toothbrush
    Make Covers for handlebar Allen Screws
    Replace Middle Gear Boot.
    Tail Light - Glue cracks from the inside.
    Adjust Triple Tree Bearings - use spanner wrench.
    Replace screw that holds metal plate covering wires on handlebar
    De-rust Philips Head Screws holding Yamaha Badge on forks.
    Clean and affix strip molding on gas tank.
    De-rust mirror rods
    New cotter pins on wheels bolts front & back
    Buff and remove scuffs on the mufflers.
    De-rust rear foot pegs.
    Replace Tachometer
    Install Venture auto-tensioner
    Clean lower front shocks
    De-rust collectors
    Modify XS11 Special collector shield & put on R. collector
    De-rust Vetter Bag trim.
    XJ11 PAINT/Touch-Up
    Paint: (gold) letters above ignition switch
    Paint: (touch up) wiring harness where L gas tank rubbed it off.
    Paint: scuffs on Instrument Panel.
    Paint: Kick Stand
    Paint: Clutch and Brake Levers
    Paint: in-between letters on Tank Badges
    Paint: Bolt heads (steel it)
    Paint: or replace washers for L front brake calipers
    Paint: Bolts for seat rails (steel it)
    Paint: Drive Shaft
    Paint: Brake Rotor Centers
    Paint: Wheel Spokes
    Paint: Handlebar controls
    Paint: Inner handlebars
    Paint: alternator & Rotor Covers
    Paint: Muffler End Plates
    Paint: Triple-Tree Clamp
    Paint: Instrument panel foot bolted to Triple-Tree
    Paint: Gas Tank (touch-up)
    Paint: Handlebar metal plates that hold in wiring.
    Paint: Luggage Rack
    Paint: Arms by middle Gear Boot
    Paint: Jugs (touch-up)
    Paint: Brake Fluid Reservoir for front brake.
    Paint: License Plate Holder
    Paint: Luggage trim
    Paint: Nuts for rear Taillight
    Paint: Airbox
    Hoo... I gots me some work ahead...
    • 3180
    More should use lists
    I make a list like that for every bike I drag home. As things get whittled down or I "borrow" a part from another bike, I find myself making a second or even third list before it finally gets done. I find that every time I make a new list some things that were missed on the first list pop up. Sometimes the list helps me to prioritize things or shift things around so I can kill two jobs at one time. An example would be, steering head bearings, fork seals, and paint triple tree parts. Once a list is formed it focuses things so you do not have do-overs.
    The other thing I have to point out is it helps decide if a project is worth it or not. Once the list is paired down to the bare minimum you know what parts you will need and the availability. The some simple research and you know if you can afford to go to functional stage or full on rebuild stage. Many on this site would benefit from using a list as yours. The whole pour gas in it and boost it and ride it thing simply does not work with over 30 yr old bikes.
    I applaud your list and the fact that you posted it so others could see it and benefit from it. I am not a list freak by any means and the bikes are about the only time I use a list (well except the one SWMBO gives me from time to time).
    I see you have a pail full of work ahead of you but it is a shorter list than some of the bikes I started with.
    Good luck and as you know We're pulling for ya.
      Lists are a good thing.... I go one better and try to do a budget. That will tell me if the bike is really worth the time/money I'm thinking about dumping into it. Luckily, on these bikes most of the 'needs' are just time things...
      • KA1J
        • 664
        • Groton, CT
        Yes lists are a plus if you want to deal with reality. Thanks to the idiocy of the POs, I have already had to do as much as is on these lists already with some being significantly greater time/expense wasters such as the unexpected ring job I probably didn't actually need to do. On the other hand, doing the ring job exposed some rusting weaknesses in the studs that would have probably become a fatal to the engine "flaw" down the road. As it is, I fixed them. Silly little things like replacing the carb screws with stainless Allen screws weren't required, I just was tired of undoing Philips screws when doing the carb checks I like to do every other year, replacing the rubber caps on the carb, dynacoils, new float valves/seats, lubing the speedo cable, total rebuild of all braking materials, Liquid taping the boots, re-upholstering the seat & so on... Some needed things & some fluff...
        Many little things that made the initial list I never wrote down, I just did them as needed and parts became available. For me, the only way to do it right is write down every new observation and decide if it's a deal breaker one way or the other. Some things like stripping the bike to the frame and repainting/polishing all metal to make the bike look as new just isn't that important to me. Having a safe bike is #1, having a reliable bike is #2 and having a clean bike is #3. If I don't have those completed I can't have a fun bike.
        As much as I like to wrench, I will be happy when all that's needed to satisfy all the above is the periodic maintenance. It will be great to sit on it and drive knowing it looks good and is good.
        • planedick
          • Mar 2005
          • 2068
          • Yorba Linda, California
          two lists
          I keep a running list all the time, with an asterisk in front of those things that are needed right away and another list of things done with date and mileage.
          Drilled airbox
          Tkat fork brace
          Hardly mufflers
          late model carbs
          Newer style fuses
          Oil pressure guage
          Custom security system
          Stainless braid brake lines
          • GLoweVA
            • Jun 2011
            • 1957
            • Virginia Beach, VA.
            My list isn't so much a todo list as it's a parts wish list.
            I've got it in excel and I highlight those parts that I need more than the others I'd like to have.
            80G (Green paint(PO idea))
            The Green Monster
            Got him in '04.
            bald tire & borrowing parts
            Scarlet
            Got her in '11
            Ready for the twisties!
            81H (previously CPMaynard's)
            Hugo
            Cold weather ride
            • Danny Crawdad
              • May 2011
              • 239
              • Birmingham, Alabama
              This post reminded me... I started a list about 8 months ago. I just went through and checked off about 10 items. Felt nice
              XS11SH :: K&N Pods, 4->1, Dynojet kit, Barnett clutch springs, TC's fuse block, ATGATT
              Well, goodness. Look what we've got here.
              • KA1J
                • 664
                • Groton, CT
                Makes me feel good too.
                I've been working on my list, abbreviated it a bit and put it in order. Anything with *** in front is now done & over with.
                PAINT/Touch-Up
                Paint: Airbox
                Paint: Black Background front Chrome Yamaha Badge
                Paint: Drive Shaft
                Paint: front brake calipers (or replace washers for L side)
                Paint: Kick Stand
                Paint: letters above ignition switch (gold)
                Paint: Luggage trim
                Paint: Tank Badges ( in-between letters)
                Paint: Wheel Spokes
                Paint: Wiring harness where L gas tank rubbed it off. (touch up)
                *** Paint: Handlebar metal plates that hold in wiring.
                *** Paint: Luggage Rack
                *** Paint: License Plate Holder
                *** Paint: Nuts for rear Taillight
                De-rust collectors
                De-rust mirror rods
                Grease Axle Splines
                Replace Tachometer
                Replace front tire
                Replace rear tire
                *** Install Venture auto-tensioner
                *** Replace cotter pins on wheels bolts front & back
                *** Replace Schrader cap for left fork air line.
                *** Replace missing bolt on backrest
                *** Replace license plate bolts.
                *** Replace screw that holds metal plate covering wires on handlebar
                *** Replace screws on front brake fluid reservoir.
                *** Replace R. bolt holding Vetter to frame (compare to L side).
                *** Modify XS11 Special collector shield & put it over R. collector
                *** De-rust Philips Head Screws holding Yamaha Badge on forks.
                *** De-rust rear foot pegs.
                I'm on my way & more to do daily till I'm done.
