Anyone use the kit from vetter? seems way over priced. What else have you used that worked?
crack in a fairing
crack in a fairing
1980 LG
1981 LHTags: None -
1980 LG
1981 LHComment
Maybe Steve or one of the other gurus/mods can come up with a Fairing repair sticky/tech tip.
I've got more than just a crack in my fairing, It's more like a split that runs up across the front and around the underside of the windshield.
Plus if one of fairing owners has some damage caused by a fender bender or drop then we've have some where to go for tips on how to repair it.Hi, my name is George & I'm a twisty addict!
80G (Green paint(PO idea))
The Green Monster
Got him in '04.
bald tire & borrowing parts
Scarlet
Got her in '11
Ready for the twisties!
81H (previously CPMaynard's)
Hugo
Cold weather rideComment
Repairs
My fairing is made of ABS plastic and I've made repairs succesfully with ABS cement and peices of ABS plastic put inside. Also the mount area, and I also installed an aluminum strip across the mount bolts to reinforce it. Triple digits are rough on the mounts. The fairing is the Vetter fairing usually found on the '79's. I will provide pics if wanted...Last edited by planedick; 05-04-2012, 08:47 AM.You can't stay young forever, but you can be immature for the rest of your life...
Drilled airbox
Tkat fork brace
Hardly mufflers
late model carbs
Newer style fuses
Oil pressure guage
Custom security system
Stainless braid brake linesComment
My Pacifico cracked up. I had installed the mounts improperly, let it flex, crack and break. Lost chunks out of the lower mounting rim. Got some 8" ABS pipe. Cut it, softened it in hot water, flattened it out. Bandsawed out filler pieces, glued in with ABS glue reinforced with layers of fiberglass. Locked it up real tight. Then I had a get-off and the bike fell over. Cracked more stuff, including the inside shell. Again, ABS glue and fiberglass covered the cracks and stiffened up the structure. Some of the damage was in visible areas. A liberal coating of glue flattens out nicely, dries hard, slick and black. Kinda looks like it's supposed to be that way. I will do some filling, sanding and painting some time, but for now it's solid again.1980 XS 11 Special: The King of Kong, 9th wonder of the world. Pacifico fairing, chopped shield, Yamaha hard bags, Diamond seat, T-Kat fork brace, XJ top end, YICS Eliminator, '80 carbs from Spyder Cycle Works, K&N Air filter, Fuse block, stainless steel valves & reg/rect from Oregon MC Parts. Raptor CCT, XJ air shocks, 850 FD, Sportster mufflers, Standard handle bar, Tusk Bar Risers, SS braided brake lines. Cat Eye speedometer. HID projector beam headlight, LED running lights.Comment
Just do like I do... Crash the bike into a guardrail, then take the pieces to someone else to fix. If they take Cherios for payment, you're set!Try your hardest to be the kind of person your dog thinks you are.
Crack in a fairing is illegal, crack in ANYTHING is illeagal.
1980 LG
1981 LHComment
i have a small crack also at the front left bolt hole/mount! sure would like to find a decent fix! ride safe ,,slow ,,mo!The Belfast Express {1980 xs11oo special/TC fuse box/mikes xs pods/bad boy horn!/mikes green coils/mac 4 into 2 exhaust/ standard bars/vetter fairing c/w ipod CD iphone am/fm radio/tkat fork brace ,,,tuned by tinman
moemcnally@hotmail.com
i AM THE KING OF NOTHING
the people here are great , doesn't matter about the bike really/hamjam ////Comment
Get ABS plumber's glue. Coat the place top and bottom. Cover the bolt hole too. Wrap it with a layer of fiberglass pressed into the glue. Cover the glass with glue. Let it dry. Drys to touch in a little while. Dries hard overnight. Clean up the edges with a sander. Repeat for another layer or two. Redrill the hole. It'll take a hard fall to break it there again.
BTW, always check that your mounting fixtures are good and tight on the bike. That matters.1980 XS 11 Special: The King of Kong, 9th wonder of the world. Pacifico fairing, chopped shield, Yamaha hard bags, Diamond seat, T-Kat fork brace, XJ top end, YICS Eliminator, '80 carbs from Spyder Cycle Works, K&N Air filter, Fuse block, stainless steel valves & reg/rect from Oregon MC Parts. Raptor CCT, XJ air shocks, 850 FD, Sportster mufflers, Standard handle bar, Tusk Bar Risers, SS braided brake lines. Cat Eye speedometer. HID projector beam headlight, LED running lights.Comment
This is the method i use pretty regularly. It works very well. Sometimes I use fiberglass mat, more often I use the fiberglass drywall tape, cut to size with scissors. The ABS cement and the tape are at home depot, and any hardware store. Wear gloves, this glue is not fun to get off your fingers.Get ABS plumber's glue. Coat the place top and bottom. Cover the bolt hole too. Wrap it with a layer of fiberglass pressed into the glue. Cover the glass with glue. Let it dry. Drys to touch in a little while. Dries hard overnight. Clean up the edges with a sander. Repeat for another layer or two. Redrill the hole. It'll take a hard fall to break it there again.
Clean the repair area with alcohol or acetone (nail polish remover), precut the tape to fit, apply a good thick puddle of cement, inset the tape, push it down flat into the cement, let it dry a while. When it's dry, still soft, or even later when it's hard, do it again: more cement , more tape. I always coat the last layer of tape one more time. I usually try to work the crack a little to get that first puddle to ooze thru to the good side just a bit, that way the cement fuses the original crack closed. Later scrape it with a blade, or sand it flush.
Hope this helps.
scootComment
Very sound advice, Scoot. I had not thought of the fiberglass drywall tape. That would work too. I used some t-shirt fabric to reinforce a broken headlight ring in my Pacifico. JB Weld didn't stick. Dried rock hard and it's been working as designed for 3 years now. Inside like that the cruddy appearance doesn't matter. Your tip on working glue into the break and smoothing it with a blade will make stronger and cleaner looking repair.1980 XS 11 Special: The King of Kong, 9th wonder of the world. Pacifico fairing, chopped shield, Yamaha hard bags, Diamond seat, T-Kat fork brace, XJ top end, YICS Eliminator, '80 carbs from Spyder Cycle Works, K&N Air filter, Fuse block, stainless steel valves & reg/rect from Oregon MC Parts. Raptor CCT, XJ air shocks, 850 FD, Sportster mufflers, Standard handle bar, Tusk Bar Risers, SS braided brake lines. Cat Eye speedometer. HID projector beam headlight, LED running lights.Comment
Hi Planedick,My fairing is made of ABS plastic and I've made repairs succesfully with ABS cement and peices of ABS plastic put inside. Also the mount area, and I also installed an aluminum strip across the mount bolts to reinforce it. Triple digits are rough on the mounts. The fairing is the Vetter fairing usually found on the '79's. I will provide pics if wanted...
Pictures please. I want to reinforce the mounting of mine before XSEast.
Phil1981 XS1100 H Venturer ( Addie)
2004 Kawasaki Concours. ( Black Bear)Comment
1980 LG
1981 LHComment
