any experience in metal flake paint??
  • GARTHXS
    • 1631
    • Seattle
    so Im thinking I want to do a green metal flake paint job , and Im wondering if anybody has any tips?
    maybe just a touch greener.
    Im thinking gold base green candy and gold flake
    91 kwaka kz1000p
    Stock
    ( Insert clever quote here )
  • GARTHXS
    • 1631
    • Seattle
    pretty cool way to apply it http://www.chopcult.com/forum/showthread.php?t=16097
    91 kwaka kz1000p
    Stock
      IT is rather difficult to spray, if you don't know what you are doing. Has an extreme tendency to run! Very thin coats of color/flake only when spraying (make sure your spray tip is large enough to pass the flake...). After coats have flash dried to the touch, with a fresh clean gloved hand rub the painted surface down, this is to knock down any flakes that are standing on end. If you clear it without doing this you will see the flakes that are standing up in the clear.
      • GARTHXS
        • 1631
        • Seattle
        yeah thats what I thought so Im going to try the method in the link above
        91 kwaka kz1000p
        Stock
          Hey Garth,
          I sprayed some green PPG auto type paint with micro flake thru a basic harbor freight HvLp type spray gun without any problems, it layed down fine. I actually applied it over a base layer of black for the patterned affect I was going for on mine....a large snake skin type pattern. Then sprayed the clear with hardener over that.
          It was the toxic type of paint, so I used a respirator type mask and goggles to protect my brains/lungs, but I live out here on the east coast, I've seen/read that you don't have this "good" quality toxic paint out here in Caca land???
          • scoot
            • Dec 2007
            • 153
            • Poway, CA: San Diego County
            here's a tip:
            I just painted a goldwing using a graphite gray with microflake mixed in it. Used a Harbor freight gun @ $14.99. Looks awesome, esp. in the sunlight. No gun clogging issues, easy to do. Here's the tip- however you spray the flake, do it in a cris- cross pattern to get an even fill. maybe two passes side to side, follow with two passes up and down, move your head around using the available light reflection to check the progress. And don't go too wet, that's where the runs are born. Just let it flash off for ten minutes, add more coats as you wish for the depth that you're after. And wait outside away from the paint while it flashes off, them's bad chemicals in the air, minimize your exposure.
            scoot
            • GARTHXS
              • 1631
              • Seattle
              Good one scoot . I do plan on using a resperater. But I'm wanting to do more of a bass boat flake
              91 kwaka kz1000p
              Stock
                • 7820
                That WILL require a large tip on the gun, and quick drying thinner for the paint. Buy some of the "cold weather" thinner, so it will flash quickly. I KNOW it helps when you are NOT a pro.... The base needs to be SMOOTH, then do a LOT of quick, thin coats of the flake, and finish with the clear. I like to put about two or three thin coats of clear so it looks like the paint is six inches deep.
                DO wear a mask, and if your like me, I used SCUBA gear to keep the lungs clean. I did shoot two coats of clear, then wet sand and a final coat to get the look I wanted. The bad news, this was thirty plus years ago, and the paint has changed a LOT since then. Even SEM paints had to change the formula for CA, so try and buy the paint from AZ or NV if you can, as it IS worth it!
                • GARTHXS
                  • 1631
                  • Seattle
                  I plan to shoot the flake on dry with q setup like a DIY soda blaster . Check out the link I posted . Any input on base coat combos
                  91 kwaka kz1000p
                  Stock
                    • 7820
                    You DO need to keep the base, flake, and top coat from the SAME COMPANY! Use the same type of paint as well!! I didn't go to the link, so I'm not sure what you are going to do, but go slow, and remember, you can always sand it and start again.
                    • Joab
                      • Aug 2010
                      • 472
                      • Ozark, Alabama
                      Make sure to post up pics of the final product...I am really interested in seeing how that color comes out...green is always a win!
                      Joab
                      "If nothing else, it will be interesting..."
                      ______________________________________________
                      1979 XS1100SF
                      1972 XS2 650
                      Ozark, Alabama
                      • TADracer
                        • 1417
                        • Kenner, Louisiana USA
                        OK, here is my opinion on applying flakes (and we all know about opinions).
                        I tried dusting flake like in the video with gold microflake. I feel better results can be had by putting the flake in the medium. I have also tried putting flake in both the last color coat and in the first coat of clear. Putting the flake in the last color coat toned the brightness down a bit for a more warm look while putting it in the first coat of clear makes it flashier and brighter.
                        Using a flaker like in the video made for a real mess. Do that outside because if you go indoors you will be cleaning flake off of everything for months. It gets everywhere. dont even breathe hard with the cap off of the container and definately wear a mask and a hair net or cap is a good idea (unless you have no hair, like me).
                        When I put flake in the last color or first clear coat I use alot less flake and clearing is alot easier with maybe three or four coats max needed to achieve depth.
                        Mike Giroir
                        79 XS-1100 Special
                          ...But I'm wanting to do more of a bass boat flake
                          You want the BIG glitter-sized flakes, which IMO is the only real metalflake paint; anything else just looks like metallic...
                          I shot one of these in the early 70s, and you need a big tip (3mm?) on the gun. Hold the gun further away from the work to avoid runs (like 16-18 inches). It took about 3 coats IIRC to get a even coat. The downside is you end up with a very rough finish that looks like the worst case of orange peel you ever saw. I cleared mine, starting with about 6 coats to get some build-up, then lightly wet-sanded to start knocking down the high spots. It took about 20 coats of clear before I had a smooth finish. This will give you a thick paint that is prone to chipping but is the only way to get a glossy finish.
                          Some guys just sealed it with 3-4 coats of clear then stopped. This works but you can't wax it because you'll never get the wax out of the dimples.
                          Of course, this was done with lacquer back then, with modern paints you'll have to stay inside their time 'windows' for proper paint bond...
                          Oh yeah... use flakes the color you want; the candy will only tint the flakes unless you do a lot of coats and it's tough to avoid blotchiness when sanding.
                          But it does look cool!
                          • GARTHXS
                            • 1631
                            • Seattle
                            I will be spraying in a booth that has very good ventilation . And I agree it will be cool
                            91 kwaka kz1000p
                            Stock
