Rather than hijack a tech thread I'll start this one.
I had to ask "what is a Redneck lathe?" and was told:-
"it's AKA a Hillbilly lathe;
a slab of nearly circular metal plate bolted to a bench grinder spindle and set to run while being shaped into a disc by holding a file against it."
Here are some others;-
Re-shape a cylindrical object by chucking it in a power drill and holding a file against it as it spins. Alternatively, spin it against a bench grinder.
Hold a valve in a bench drill to sand the carbon off it.
A bench drill will also work as a vertical lathe, using a file or emery tape on the workpiece.
Or as a vertical grinding fixture, use in conjunction with an angle grinder
And as a press (unplug it for this one) to hold a screwdriver bit down hard onto a stuck cab jet to back it out by hand turning the drill chuck.
Absent a chopsaw, cut steel with a 7" abrasive disc in a Skilsaw or a 9" or 10" abrasive disc in a table saw.
