Hey folks,
Okay, I thought that there were a few real electricians on here, so here's a question. I got that little 3-1 welding machine that's capable of running on 110V as well as 220v. It says that it can pull up to 50 amps at 220v for the plasma cutter as well as the TIG function.
My compressor runs on 110v, but puts a load on the garage circuit, and I can't run the welder AND the compressor at the same time both being on 110 on the same circuit. And for the Plasma cutter it requires 70psi 4 cfm air flow rate, and my~25 Gallon tank can only provide maybe a minute's worth before it will drop below the 80psi auto-on level to refill back up to 120 psi level.
SO...I'm looking to drop a 220v Line and socket in the garage. The fuse panel is on the same wall where I want to put the line. ALSO I just remembered that we had an electric stove/oven when the house was first built, and we switched it to GAS several years later, so there should be an unused 220v tap already running from the fuse panel and under the house.
I'm just asking for a rough estimate of what you would charge to put in the line, whether being able to cut and then pull the old stove line and reroute it along/inside the garage wall to the socket vs. just running a new line, plus the cost of the socket AND Plug.
The Plug that came with the unit is a NEMA-6 from what I was able to research, L6-30P are stamped on it, along with 30A and 250v rating?? The unit is supposed to possibly draw up to 50 amps at full capacity, so I'm thinking that I may need a different style plug that is rated a bit higher in Amps? I was told that the power transformer is autosensing both voltage and frequency, but that the plug uses 2 hots and a ground but no NEUTRAL!?Both in the 220v as well as 110v mode! The socket would only need to be maybe 10 feet away from the fusepanel, on the same wall.
Can anyone give/tell me a quote as well as any other info they seem fit for me to know, like if the 30A plug would be sufficient vs. some other type?
Thanks in advance.
Thanks in advance.
