IE9 weirdness...
    IE9 weirdness...
    Well, I got 'upgraded' to IE9 and a heads-up; posting pics now works different...
    I tried using the 'insert image' icon and the pic doesn't show up, just the red X in the box...
    But when I used the 'insert link' icon, it's there....WTF?
    Anybody else run into this?
    • 9980
    I've always just used the IMG code from photobucket.
      That's what I'm using, but the prompts have changed. Where before when you clicked on any of the 'insert' icons in the message toolbar, you got a 'allow script' message at the top of the screen. You had to click on that, then re-click the insert icon before you could paste the URL. That has now disappeared, now I get a 'V-bulletin' window right off the bat where you paste. I'm using the IMG code from PB, but if I use it with the 'image' icon the pic doesn't come up. Use the 'link' icon and it does...
      It seems to be working backwards.
        Here's an example.....
        'Insert image' icon....
        [/IMG]
        'Insert link' icon...
        http://
        See what I mean?
          • 9980
          I don't even use the insert icon, just put the IMG code right in the post.
            Never tried that, let's see if it works....
            Well, learn sumpin' new every day....
            • cywelchjr
              XS-XJ Super Guru(Deceased)
              • 4450
              • Sacramento, CA
              I've never used the insert image icon because I've always seen that anyone that used it has always had an extra [IMG] tag in front of the image and an extra [/IMG] tag after the image because photobucket already puts all of that in the code it puts in the clipboard when you click that dropdown menu, so you get it doubled, IE9 must be trying to fix it on the fly. If I understand the picture link thing, it's for pointing to where you only have the http address of the picture without the tags, but I've not seen that since even though my version of IE has been 9 for quite some time I've not used IE for anything that didn't pretty much required it for a couple of years now at least, I use Google Chrome, at least when I'm not using my tablet or phone.
                • 9980
                  The only time you need to use the Image link button is when you want to insert an image that is displayed somewhere other than a Photobucket "bucket". You can post the web address of ANY static picture from anywhere on the web (as long as no login is required to get there) and have it display in your post. I outlined this in my picture-positng instructions here.
                  • tweeleft
                    • May 2009
                    • 110
                    • Bend Oregon
                    I gotta try this
                    Keep the shiny side up
                    1979 XS1100SF
                    Mac 4-1
                    Drilled airbox Uni filter
                    Vmax bars
                    Virago 1" shorter shocks
                    30K miles
                    http://i1228.photobucket.com/albums/...429_135845.jpg
                    1981XS1100SH
                    '80 G Forks and Triple Tree
                    '80 G tank
                    Mac Turnouts
                    Virago 1" shorter rear shocks
                    SH Headlight
                    http://i1228.photobucket.com/albums/...psd6adaae1.jpg
                    61 Wife
                    83 Son
                    86 Son
                    89 Daughter
                    • tweeleft
                      • May 2009
                      • 110
                      • Bend Oregon
                      cool it worked
                      1979 XS1100SF
                      Mac 4-1
                      Vmax bars
                      30K miles
                      1981XS1100SH
                      '80 G tank
                      Mac Turnouts
                      SH Headlight
                      61 Wife
                      83 Son
                      86 Son
                      89 Daughter
                        • 3177
                        If you hit the enter key and start a new line before the copied image the words will appear above the picture. If you hit enter a couple of times the pics will have spaces between them. If you do not hit enter and keep on adding to the same line one after another we will have to scroll across to see the pics.
                        Nice bike try a few more pics just for giggles.
