Laugh
  • mack
    • 2411
    • Ontario, Canada
    Laugh
    Just in case you need a laugh: Remember it takes a college degree to fly a plane, but only a high school diploma to fix one; that's reassurance to those of us who fly routinely.
    After every flight, UPS pilots fill out a form, called a 'gripe sheet,' which tells mechanics about problems with the aircraft.
    The mechanics correct the problems, document their repairs on the form, and then pilots review the gripe sheets before the next flight.
    Never let it be said that ground crews lack a sense of humor. Here are some actual maintenance complaints submitted by UPS pilots (marked with a P) and the solutions recorded (marked with an S) by maintenance engineers.
    By the way, UPS is the only major airline that has never, ever, had an accident...
    P: Left inside main tire almost needs replacement.
    S: Almost replaced left inside main tire.
    P: Test flight OK, except auto-land very rough.
    S: Auto-land not installed on this aircraft.
    P: Something loose in cockpit
    S: Something tightened in cockpit
    P: Dead bugs on windshield.
    S: Live bugs on back-order.
    P: Autopilot in altitude-hold mode produces a 200 feet per minute descent
    S: Cannot reproduce problem on ground.
    P: Evidence of leak on right main landing gear.
    S: Evidence removed.
    P: DME volume unbelievably loud.
    S: DME volume set to more believable level.
    P: Friction locks cause throttle levers to stick.
    S: That's what friction locks are for.
    P: IFF inoperative in OFF mode.
    S: IFF always inoperative in OFF mode.
    P: Suspected crack in windshield.
    S: Suspect you're right.
    P: Number 3 engine missing.
    S: Engine found on right wing after brief search
    P: Aircraft handles funny. (I love this one!)
    S: Aircraft warned to straighten up, fly right and be serious.
    P: Target radar hums.
    S: Reprogrammed target radar with lyrics.
    P: Mouse in cockpit.
    S: Cat installed.
    And the best one for last
    P: Noise coming from under instrument panel. Sounds like a midget pounding on something with a hammer.
    S: Took hammer away from the midget
    __._,_.___
    mack
    79 XS 1100 SF Special
    HERMES
    original owner
    81 XS 1100 LH MNS
    SPICA
    78 XS 11E
    IOTA
    https://youtu.be/wB5Jfbp6SUc
    https://youtu.be/RaI3WYHSuWA
    Frankford, Ont, Canada
    613-398-6186
  • je2wheeler
    • Feb 2010
    • 180
    • Moved to NC to help my Dad
    __._,_.___
    Competition between parcel delivery companies must be stiff if UPS is installing IFF (Identification friend or foe) and targeting radar systems on their aircraft.
    1979 XS 1100 Special - Nicknamed "MONSTER"
    ATC fuse box
    Braded stainless brake lines
    4/2 aftermarket exhaust(temp until stock is re-chromed )
    V-Max auto cam chain adjuster
    Brake light modulator with reserve brake light bypass
    Vetter Windjammer III faring
    Tkat Fork Brace
    "Americans have the right and advantage of being armed; unlike the citizens of the countries whose governments are afraid to trust the people with arms”
    James Madison, The Federalists Papers
    • old_skool
      • Nov 2011
      • 554
      • Ohio
      Thanks, having been in army aviation, that had me laughing good.
      81 XS1100H
