Hey everyone,
I had a question about valves. I have recently completed the total rebuild of my 79 xs1100. I have gotten alot of good info from everyone that has helped me get to the point of completion. However, I have a new problem. The bike has ran very little, but has ran good. After the bike setting for a week of cold weather in the garage, we got a good day and I decied to take it out of the garage and start it. I was just going to let it run a bit to keep things loose. I began to have problems keeping it running. I pulled the air filters and fired it up again. The number for carb began to pop back with gas. I assumed and intake vale might be sticking. I ran a compression check and sure enough #4 had zero. All the valves in this motor has been replaced with new ones and all lapped in well. When I removed the head I found the exhaust valve was bent? No signes of contact on the piston and timing was still where I had set it originally. Any ideas what caused this? Is it possible the engine got hot and warped that valve? I did paint the head, but removed the paint from the edge the fins. It gave it a really nice look. But have I created a problem with cooling? Any assistance would be greatly appreciated, spring is coming and I want her ready to ride.
