Hi guys, I do know that zinc chromate primer is used for aluminum - here's my question. I'm making a custom exhaust for a Suzuki Savage. I ordered "aluminumized" steel tubing which means it's coated in aluminum. Should I just use the high temp paint directly on it or use the zinc chromate primer first. I'd like to use the primer becuase I know aluminum doesn't take paint well, but I also don't know if zinc chromate primer can take the heat. Anyone have any knowledge on this?
Zinc Chromate primer - anyone know about this stuff?
aluminum oxide primer would be a better option for adhering to alloy but I don't know if it will take the heat. I have not used the stuff in years.
RobKEEP THE RUBBER SIDE DOWN
1978 XS1100E Modified
1978 XS500E
1979 XS1100F Restored
1981 Suzuki GS1100
1983 Suzuki GS750S Katana
1983 Honda CB900 Custom -
I've used zinc chromate extensively on outboard motors, but have no experience with it on high temp applications. It works great in the marine environment.1980G Standard, Restored
Kerker 4 - 1
850 Rear End Mod
Automatic CCT
1980GH Special, Restored
'82 XJ1100 (Sold)
Automatic CCT, RC Engineering 4 X 1 Exhaust, K&N Pods, #50 Pilot Jets, YICS Eliminator. Sorely missed.Comment
The new Zinc chromate primer is not the same as the REAL old time ZC. The old stuff was a butyrate dope base, which made it fuel proof. The new stuff will have the binder/carrier base listed on the label, but unless it states it is for hi temp application, it will probably degrade with heat, and I would avoid it. If you have a rattle can of it, try it on a piece of pipe, and apply a propane torch to it to see what happens.
Jasco makes a metal prep that has phosphoric acid in it, and that, applied to the pipes, rinsed off after a few minutes, then dried, would prep the metal for a coating of Hi Temp paint. Read the label, and use the instructions for new aluminum or steel metal.
Or, you could do what us po-boys do, and coat the pipes with oil, and heat them up. Turns 'em black or brown. CZComment
