Hey Folks,
Just wanted to talk a little about cordless drills and their battery packs. I have both an older 7.2 V Ryobi drill/pack, and a B&D 14.4V drill/pack.
The B&D charger died(tested with voltmeter), it merely plugged into the back of the drill to charge the attached battery. Got a larger slide attachment charger requiring removal of battery pack from drill to charge it. Test charged the pack with new charger for 5 minutes, voltage was too high, would not run the drill. I tested the drill with separate 12 volt battery, worked fine! Took battery pack apart, found exploded corroded cell amongst the 12 cells in the pack. It takes the 4/5 Sub-C style Ni-Cd battery. This bad pack/cell is probably what burned out the OEM charger.
The Ryobi 7.2 V pack has 6 Full Sub-C Ni-Cd batteries, they are just OLD and worn out, will hold "some" charge, but not very much or very strong. So I've decided to replace/rebuild both packs.
I know that HEAT is the Ni-Cd battery's enemy and that I can't simply solder tabs to the batteries to be able to link them up! However, I have been able to find both styles of batteries with built in solder tabs, so I can use my low heat Cold/Heat battery powered soldering device to quickly solder the tabs together while not sending/putting much heat into the actual battery itself.
Due to the old style of battery charger, I decided to stay with Ni-Cd batteries instead of Ni-Mh, plus with this application...DRILLs, the Ni-Cd's can discharge/provide their power quicker and more completely than the Ni-Mh and I won't have to worry about compatibility of the old chargers.
The batteries are coming from Hong Kong via Ebay, the 12 set for ~$18.00, the 6 set for ~$10.00..free shipping for both. I've taken photos, marked the (+) and (-) ends of each cell to be able to replicate it precisely in the new pack arrangement.
I'll be letting folks know how it turns out, works, etc., just curious if others have attempted to do this? I don't have one of those fancy battery welders that professional pack rebuilders use for this purpose, but am hoping that with using the pre-tabbed style batteries, I'll be able to link them without heat damaging the batteries, and have new battery packs for easily 1/2 or less expense than buying new packs or Professional rebuild.
