I got this in a email from a fellow mechanic and thought some of you might find it amusing...I did!
HAMMER: Originally employed as a weapon of war, the hammer nowadays is used as a kind of divining rod to locate expensive parts not far from the object we are trying to hit.
MECHANIC'S KNIFE: Used to open and slice through the contents of cardboard cartons delivered to your front door; works particularly well on boxes containing seats and motorcycle jackets.
ELECTRIC HAND DRILL: Normally used for spinning steel pop rivets in their holes until you die of old age, but it also works great for drilling mounting holes in fenders just above the brake line that goes to the rear wheel.
PLIERS: Used to round off bolt heads.
VICE-GRIPS: Used to round off bolt heads. If nothing else is available, they can also be used to transfer intense welding heat to the palm of your hand.
OXYACETELENE TORCH: Used almost entirely for lighting various flammable objects in your garage on fire. Also handy for igniting the grease inside a brake drum you're trying to get the bearing race out of.
WHITWORTH SOCKETS: Once used for working on older British cars and motorcycles, they are now used mainly for impersonating that 9/16 or 1/2 socket you've been searching for for the last 15 minutes.
DRILL PRESS: A tall upright machine useful for suddenly snatching flat metal bar stock out of your hands so that it smacks you in the chest and flings your beer across the room, splattering it against that freshly painted part you were drying.
WIRE WHEEL: Cleans rust off old bolts and then throws them somewhere under the workbench at the speed of light. Also removes fingerprint whorls and hard-earned guitar callouses in about the time it takes you to say, "Ouc...."
SNAP-ON GASKET SCRAPER: Theoretically useful as a sandwich tool for spreading mayonnaise; used mainly for getting dog-doo off your boot.
E-Z OUT BOLT AND STUD EXTRACTOR: A tool that snaps off in bolt holes and is ten times harder than any known drill bit.
TIMING LIGHT: A stroboscopic instrument for illuminating grease buildup.
BATTERY ELECTROLYTE TESTER: A handy tool for transferring sulphuric acid from a battery to the inside of your toolbox after determining that your battery is dead as a doornail, just as you thought.
PHILLIPS SCREWDRIVER: Normally used to stab the lids of old-style paper-and-tin oil cans and splash oil on your shirt; can also be used, as the name implies, to round out Phillips screw recesses.
AIR COMPRESSOR: A machine that takes energy produced in a coal-burning power plant 500 miles away and transforms it into compressed air that travels by hose to a pneumatic impact wrench that grips rusty bolts last tightened 60 years ago by someone in Detroit, and rounds them off.
HOSE CUTTER: A tool used to cut hoses 1/2 inch too short.
Thanks needed that.
