Am I the only one this lazy?
  • Filter
  • Am I the only one this lazy?
    So I was tuning my CB750 yesterday and I noticed that I had somehow left an extra hose clamp dangling on the downtube of the frame. It wasn't one of the four holding the Vetter fairing, just one I apparently meant to use but forgot about.
    Since I was tuning the bike I only had a phillips screwdriver and a very small Craftsman flathead, barely bigger than my jewelers screwdrivers, at hand. I started turning the clamp screw (which I had apparently decided needed to be tighten almost all the way) with this little screwdriver. It did not grip well. I was lucky to get one-quarter turn before it would slip. When it did it was a bit difficult to get it going again because it was below the fairing and dark and I couldn't see the screw head. So I had to do it by feel. It took like, forever, to get that clamp off. It was very frustrating.
    Now, the thing is, I was sitting on my mechanics stool not four steps from my workbench. At my workbench I have a drawer that holds two complete sets of Craftsman screw drivers, as well as an assortment of other screwdrivers, bit drivers and specialty drivers, including even some JAS screwdrivers I bought when I rebuilt by first Jap bike many years ago. As I was sitting there getting frustrated by that clamp I thought at least twice that I should get up, take four steps, and get the right tool. I did not. It seemed like too much trouble. Four steps.
    I find I do that a lot. I work with the tools immediately at hand instead of getting off my stool and getting the right tool. I will sit, surrounded by probably $7,500 worth of tools; enough tools to pull and rebuild any engine in anything; and I will first try to remove a socket head bolt with a jewelers screw driver before taking that long walk.
    Just out of curiosity, am I the only one who does this?
    Patrick
    XS11F (Incubus, daily rider)
    1969 Yamaha DT1B
  • #2
    yes, you are. I have never done anything like that
    Seamus Ó hUrmholtaigh
    Niimi Moozhwaagan
    NOTICE: No trees were destroyed in the sending of this message. We do concede, however, that a significant number of electrons may have been inconvenienced.
    Any connection between your reality and mine is purely coincidental.
    Member of "FOXS-11" (Former Owner of XS-11)
    and SOXS
    2008 Nomad "Deja Buick'
    • #3
      No, I've never done that. I always get up and get the right tool. Even if it's on the other side of the garage. I would never make do with the tool I can reach without getting up when the right tool is a few steps away.
      • #4
        At least you know where your tools are Pat. I usually will get up to go get what I need from where it's supposed to be and it's not there. Which leads to a cuss fest while I storm around the garage looking for it and finally find it sitting right next to what I'm working on. It wasn't there when I looked the first time.
        BTW........find a box yet?
        • #5
          Let me get on that this week, Greg. I'm finally at a pausing point on all my projects while I wait for parts.
          1969 Yamaha DT1B
          • #6
            I would have to agree with Greg, that is usually how it goes for me too.
            Yeah, did you find a box yet!
            • #7
              I would never do that, although I have five 12mm sockets and can never find one when I need it.
              • #8
                LoHo, You just have to find the right words and they will appear like MAGIC!!!
                • #9
                  And all at once.
                  1969 Yamaha DT1B
                  • #10
                    That's kind of like using a 13mm socket to remove a 12mm bolt. You might be able to remove it but if you don't you'll have a stripped head you'll pay for dearly later. That's most applicable to phillips and slotted head bolts where you can't really apply the proper ammount of pressure to break them free if you don't use the right size driver. When you strip them you not only have to figure out how to get them out, but then have to replace them....
                    1980G Standard, Restored
                    Kerker 4 - 1
                    850 Rear End Mod
                    Automatic CCT
                    1980GH Special, Restored
                    '82 XJ1100 (Sold)
                    • #11
                      But if it saves four steps....
                      1969 Yamaha DT1B
                      • #12
                        Now that IS lazy......
                        • #13
                          Quote: LoHo, You just have to find the right words and they will appear like MAGIC!!!
                          I have a little ritual that works: if I use an open end wrench to eventually get the bolt loose, as I set it down, it hits a 12mm socket.
                          • #14
                            Nope. Not me, never...
                            Everything on hold...
                            • #15
                              I was going to try to formulate a witty remark, however, I just couldn't find the energy it required.
                              Ernie
