There are 2 styles of SSD drive construction: SLC and DLC. The first stands for Single Layer Cell and the later stands for Multiple-Layer Cell. Currently the SLC drives are the faster and have a life expectancy of about 25 percent longer than SATA drives that run at either 10,000 or 15,000 RPM. Samsung makes a number of SLC drives. SLC drives are generally considered to have a longer life expectancy than the MLC drives. This information is via VMWare and Cisco, who now offer SSD drives in their networking and storage equipment. They use SLC drives exclusively.
People who make the less expensive MLC drives are working to find ways to close the "how long does it last" gap, and my information will probably be out of date within months. However, as it stands today, SLC drives will outlast MLC drives by a considerable margin, and SLC drives will have an average life span greater than SATA drives.
Generally, the specs for an SSD drive should tell you if it is SLC or MLC. It will say something like "SLC flash memory" or "MLC flash memory."
Either style is likely to give your PC a performance boost, and the differences are largely academic for a home system. However, if you are looking at high-powered systems, systems for business, graphics-intensive or other higher-end applications, you may want to seek out SLC drives.
I'll have to take another look at SSD tech and see if they'd make sense for me.
