Anyone know a good source for wire?
  • 81xsproject
    • 3185
    • Fortuna, CA
    I want to redo my wiring on my MS system and have been trying to find a source to get lots of different colors/patterns of wires without buying 20 separate rolls. I thought about buying a harness on ebay and stripping it down, but I don't like the idea of using old wire. I only need 4-5 feet and maybe a dozen or so different colors/patterns. Anyone have any ideas?
    '81 XS1100 SH
    Sep. 12th 2015
    RIP
    Hmmm, I don't have an answer for you but I am also trying to find some wire. I am looking for some very small gauge wire for LED lights. I want to run 2 wires through the mounting bolt (thats a real small hole) so I can have front running lights.
    • MrOzz
      • Aug 2008
      • 782
      • Massachusetts
      Try here:
      lots of different gauges and colors and you can get it by the foot.
      Hope this helps,
      Ozz
      1980 XS 1100SG
      Dyna 3 Ohm Hi Output Coils
      Pod Filters
      DynoJet Kit
      T.C.'s Fuse Block
      V-Max Auto CCT
        Think you could get 2 -22 gauge wires through that mounting bolt hole?
        • MrOzz
          • Aug 2008
          • 782
          • Massachusetts
          I dont see why not.
          1980 XS 1100SG
          Pod Filters
          DynoJet Kit
          T.C.'s Fuse Block
          V-Max Auto CCT
          • planedick
            • Mar 2005
            • 2068
            • Yorba Linda, California
            2 wires?
            You only need one wire if the mounting bolt is attached to the bike where it's grounded.
            Drilled airbox
            Tkat fork brace
            Hardly mufflers
            late model carbs
            Newer style fuses
            Oil pressure guage
            Custom security system
            Stainless braid brake lines
              As I said earlier on the thread, I want to put in led running lights, need 2 wires for that.
              • planedick
                • Mar 2005
                • 2068
                Why 2?
                I just don't understand I guess. You need a hot lead and a ground for any LED I've ever seen...
                Drilled airbox
                Tkat fork brace
                Hardly mufflers
                late model carbs
                Newer style fuses
                Oil pressure guage
                  Telephone wire Nate. You know, the stuff with 4 little wires encased in sheathing?
                  It's real small and it conducts really well. I've used that stuff on car stereo speakers before, It should be OK for LEDs.
                    • 8928
                    Bunch of links for wire sources in this thread...
                      Hi Dick,
                      like in the joke punchline:- "Don't go! It's a trap! There's two of them!"
                      In this case, an LED for a running light and another LED for the flasher.
                      • b.walker5
                        • Feb 2009
                        • 1745
                        • Invercargill, New Zealand
                        I just go to my local Auto Electrician and buy what I need by the metre. Can be a little more expensive but it's still cheaper than buying complete rolls and having lots left over.
                          As Fred started eluding to, if you use the turn signals as running lights also then you have to use a dual circuit bulb. With a dual circuit bulb you need 2 hot wires to operate the 2 circuits. One circuit for the turn signal and a second circuit for the running light. Both circuits still ground through the stem though.
                          • 81xsproject
                            • 3185
                            • Fortuna, CA
                            Originally posted by MrOzz
                            Try here:
                            Hope this helps,
                            Ozz
                            That is EXACTLY what I was looking for but could not find. They have 49 different colors/combos. Minimum length is 5' (not bad). Definitely bookmarking that site. Not the cheapest but with that selection, you could match up to most factory colors. Now all I need is to see what I need. Thanks all.
                            '81 XS1100 SH
                            Sep. 12th 2015
                            RIP
                            • planedick
                              • Mar 2005
                              • 2068
                              Missing info
                              I guess if it was stated I missed it. I thought there was only one circute/bulb.
                              Drilled airbox
                              Tkat fork brace
                              Hardly mufflers
                              late model carbs
                              Newer style fuses
                              Oil pressure guage
