Samsonite Restoration
  • latexeses
    • Jun 2008
    • 1491
    • California
    I have come across a set of Samsonite luggage that has "greyed" or "dried out" if you will. I tried the Armor All and it works pretty well, to a point, but it doesn't look like it will do the job I am after. Short of a full soak, maybe...
    I may give rubber restorer 79XS11F used on an isolated spot just to see what happens. But I'll wait for input first.
    I haven't kept up with the car care industry and all of the latest "elixers" out there made for such things.
    Looking for some input on what some of you have used or know of, that might put the "dark" back in the bags.
    Thanks in advance.
    Rodger
    Everything on hold...
  • xsroadrunner
    • Nov 2010
    • 262
    • Southern Comfort
    Vinylex
    1982 XJ1100 MadMax-im
    2001 Honda ST1100
    • latexeses
      • Jun 2008
      • 1491
      • California
      Is Vinylex that much different than Armor All? Sort of reads like the same mode of cleaning. Never seen it before.
      I looked through a search for cleaning luggage and other key words here and didn't get close to anything like a discussion on restoration.
        Originally posted by latexeses
        I have come across a set of Samsonite luggage that has "greyed" or "dried out" if you will. I tried the Armor All and it works pretty well, to a point, but it doesn't look like it will do the job I am after. - - -
        Hi Rodger,
        Samsonite bags are hard plastic? If so, auto rubbing compound and a power buffer should work. It rips the faded layer off the surface.
        • xsroadrunner
          • Nov 2010
          • 262
          • Southern Comfort
          I'm not sure abt the comparison to Armor All...they could be quite similar but my feeling is that its a better product.. I use Vinylex on all my plastic and vinyl surfaces and it has worked quite well...so I am happy with it.
          2001 Honda ST1100
            If the plastic is sun-bleached, there isn't anything that will truely bring the color back except for Fred's suggestion, but that will destroy the texture on the bags. Best bet is paint; spray a light wet coat on. Rattle-can paint can work, but you'll get the best results by using a detail gun and mixing the paint thin with about a 60/40 mix of paint/reducer. But if you've already tried any sort of 'treatment' such as Armour-all, getting the paint to stick will be difficult. Try a professional pre-paint cleaner/prep before giving it a go...
            • tom clisham
              • Sep 2010
              • 627
              • Northern Illinois
              rattle can(?)
              all the home centers now carry rattle cans blended specifically for plastic.
              might be worth a try.
              Tom Clisham
              Age is relative YOU WON"T GET OLD TIL YOU SELL THE BIKE
              _____________________________________________
              '78xs1100E ,all stock & original GONE TO WISCONSIN
              '80 SG Vetter fairing,hard bags,trunk,fork brace,
              stock headers with fishtail mufflers,black & beautiful GONE TO ARIZONA
              79SF lowered,jardine 4/2 exhaust,pod filters,drilled rotors,fork brace, bar hopper
              79SF 1 owner,8000 miles, restoring to completely original ( I hope) GONE TO FRANCE
              • latexeses
                • Jun 2008
                • 1491
                • California
                xsroadrunner,
                I am a bit leary of using anything I can't get off it I wind up having to use some sort of treatment that needs to "stick" to the surface but I need to experiment anyway. Always work on the car!
                fredintoon,
                Not sure what they are exactly they sort of look like a thin version of the ABS of the fairings. The "oxidation?", I guess that is the best description, doesn't seem to be very deep. If I rub my thumb nail on the surface it seems to be just the thinest layer.
                crazy steve,
                I stopped short of hosing all of one bag when I was trying the Armor All. I have a "touch up" gun that is the right size for the job.
                The finish is a pebbled finish that is fairly fine.
                tom clisham,
                I had forgot about that paint. Don't know how rugged it is though. I may give it a try on somehting else first.
                • jwhughes3
                  • 2798
                  • Home of the Alamo
                  shoe hospital
                  try a local shoe hospital for tips - the material must be similar to some shoe materials and they can buff or restore about anything.
                  John
                  '81 XS1100H - "Enterprise"
                  • xsroadrunner
                    • Nov 2010
                    • 262
                    • Southern Comfort
                    xsroadrunner,
                    Nothing to be leary of...if you have used Armor All then really this stuff is quite similar...
                    2001 Honda ST1100
                      Contact samsonite and see what they might suggest.
                      • latexeses
                        • Jun 2008
                        • 1491
                        • California
                        jwhughes3,
                        Used to have a great cobbler in town but he went the way of the buggy whip salesman just a couple of years ago.
                        natemoen,
                        I sent Samsonite an email with the question about restoring the bags but have yet to hear from them.
                        I suspect that a question about 25-30 year old motorcycle bags is not high on their priority list. Especially since they are not making a replacement.
                        xsroadrunner
                        Took a trip out to the local Pep Boys and looked at a product from Mothers called Back to Black and another product from Bondo called Restore Black. It seemed to be a black gel. Claims to "Restores Black Color To Faded Vinyl, Rubber And Plastic Surfaces".
                        Anyone ever used any of these?
                        Thanks,
                          I have used mothers back to black on a lot of old plastic, works well but don't know how it would work for you. Wiped pretty much all of the black plastic parts from my xs down with it (sometimes it take several coats) and it made them all a nice shiny black again.
                          • soccer4m
                            • 694
                            short time
                            I used Back to Black and it looks good, but only for a short time and it builds up a greasy residue over usage. For a quick fix look its good but I found it expensive and fades after a couple of weeks. I used it on car bumpers that were faded...,,,it might last longer if surface is inside mostly, but the sun kills it quickly if outside............found that a thorough cleaning and protectant is about all that can be done on really faded stuff, other than painting. Maybe the product vinylex,,havent used it but a lot on the site swear by it............keep us informed,,,,,,,Mike in Sun Diego
                            mike
                            1982 xj1100 maxim
                            1981 venture bagger
                            1999 Kawi Nomad 1500 greenie
                            1959 wife
                            • barrelguy
                              • 171
                              • Oliver, BC
                              jwhughes3,
                              natemoen,
                              xsroadrunner
                              Thanks,
                              I used Back to Black on my fairing surfaces. It works great on textured finishes but I had a problem with a streaky film when I tried it on smooth surfaces (side covers, etc.) I contacted the company and they suggested Mother's Plastic Polish for the smooth stuff.
                              1980 XS 1100 Special
                              Mostly stock & original
                              Added Yamaha fairing (w/ 8-track!)
                              Torpedo bags
                              New paint (still) pending
                              Stainless brake lines
                              Tkat forkbrace
                              Coils from Honda 1000
                              Previous bikes:
                              1968(?) 350 Harley Davidson
                              1977 Yamaha 650
