Hey folks and fellow geeks!
Apologies in advance for the length of post.
Okay, I've had my homebuilt system running for 1.5 years, installed my OLD PURCHASED Windows XP Home onto it, had to get the special 50 digit code from MS because it had already been used/registered with a totally different machine. It had been upgraded to SP2 and then SP3, running good quality Antispy/virus programs, recently checked for root kits and such=CLEAN.
Had been installing ALL MS autoupdate security updates and such all along.
I had been using IE7 because of the reported bugs with IE8 from a year ago, and I didn't like the IE8 interface/tools/menus layout. Well after some RECENT "routine" MS autoupdate pushes, and also the recent JAVA Auto Update and Flashplayer updates, I then tried to use IE7 and it wouldn't RUN. Would partially open, showing just large WHITE screen. I tried it with NO Add-ons, same thing.
SO...I thought it was finally fried, so I installed IE8. SAME thing, or worse, would pop up for second or so and then just close, no error messages, etc.!
A couple of other OLD programs also didn't want to work right...like a very old graphics editting program that I had gotten with an old scanner 10+ years ago!
Picture Publisher version7. Just was telling me that I didn't have a Printer selected/installed....I had not changed it, and the printer still showed in the Printers CP applet. I found a newer version...10 for free download, installed it and it then worked.
The other program was a slightly newer but still old MediaFace 4.01 CD/DVD label maker/printer program...it actually stopped working/wouldn't load? I then downloaded their version 5, tried to install it and got some funny Install Shield errors, could never get it to work/install.
So..then I tried a RESTORE point...I've NEVER had to use a RESTORE before on this computer! I selected one a week prior to the updates. After it was done, my Graphics editting program and MediaFace would work, but IE7 would still not work...but I didn't try to Uninstall it before doing the RESTORE!
I've installed Firefox, and it works just fine. I know IE is wrapped up in the Windows OS, it's just that I've been used to IE, and would like to get it working, BUT I don't want to go thru a complete REINSTALL of the OS.
I've read online/searches that trying to use SFC may not work because of it being SP3 NOW, and the SFC I have on my original install is SP1, etc., or that IF it does repair things, I would have to go back and re-install Sp2 and 3?
I've got a second slave computer running XP Pro, Sp3, and have installed IE8 on it, and it's working, and am doing incremental update installs...custom selecting them 1 by 1, then checking IE8 to see if it's still working to see if I can figure out which update may have caused the problem, but not sure if it'll show/happen??
I don't really want to "bother" with the OS reinstall and then all of the other programs I would have to reinstall! I can use Firefox, and probably other browsers. Some of you may say just don't bother fixing IE, and use the other browsers. I'm still on the 1 week earlier restore point. Should I go back to the later IE8 original restore point to try to Uninstall IE8 before then applying the 1 week earlier restore point?? Fishing for ideas!
