Blowing (not burning) oil?
  • rfbatman
    • Apr 2003
    • 43
    • San Diego
    Anybody got any ideas?
    My 81 XS1100 Special is blowing out about a quart of oil every 150-200 miles. It is visible from underneath the cover.
    I put on a new valvecover gasket a few months ago thinking that would fix it. But I am seeing oil by each of the rubber spacers (if that is what they are called) between the fins. As you can tell, I am not in the least bit mechanical so the description of the problem area is not so good. It is happening only on the right side of the engine (thats from the "on the bike" view).
    I spoke to my mechanic and he indicated blowing oil is a much better problem that burning oil.
    Does anyone have any suggestions before I give it to him for service that would give him a starting point? The bike is running great, but this is a pain.
    The knowledge base on this site is awsome so I know your suggestions on how to correct will be a great starting point for my mechanic.
    Thanks in advance,
    Rick
  • sambodie
    • Mar 2003
    • 26
    • Channelview, TX
    Did you replace the half-moon rubber gaskets when you replaced the cam cover gasket? I would try that and also check the breather tube to be sure it isn't blocked.
    Sam Bodie
    • Ken Talbot
      • 4251
      • Revelstoke, BC
      Try running a finger over the rubber plug in the end of the camchain slack adjuster. If you get even a slight trace of oil there, that is probably your problem. Under way, any oil seeping out there can get blown back to the rear of the motor and look like is coming from all kinds of places.
      Ken Talbot
      • rfbatman
        • Apr 2003
        • 43
        • San Diego
        Thanks Sam and Ken. I'll pass both those suggestions to my mechanic.....and no I did not replace the half moon rubber gaskets.
        • mitch
          • Oct 2002
          • 934
          • fredericton new brunswick canada
          How to find it
          A friend told me this once , degrease the engine then let it dry good (overnite ) then take it for a 5 to 10 mile run . When u get back take some baby powder and spray it around the engine, hopefully you will see where the oil is coming from. Worth a try.......MITCH
          Doug Mitchell
          82 XJ1100 sold
          2007 Stratoliner 1900 sold
          • fusionking
            • Feb 2003
            • 453
            • lake of the ozarks MO
            Now that is a good idea....definitely out of the box...thanks Mitch
            Garry
            '79 SF "Battle Cat"
            outbackweld@charter.net
            • rfbatman
              • Apr 2003
              • 43
              • San Diego
              Blowing oil from top of engine fixed.
              That did it. I ordered the half moon gaskets from Partsnmore.com for 2 bucks apiece and that did the trick! Drove the bike 40 miles today and not a trace of oil on the engine and the oil level did not drop.
              Thanks to all for their suggestions.
              Rick
              • buffalo
                • Aug 2002
                • 141
                • Carson City, NV.
                I say it's not leaking oil... just sweating horsepower!
                buffalo
                80 XS1100SG
