Had a cheap ipod radio but that died, now I use my.phone and Pandora radio.
Work bench, how tall?
Can cut top out of a sheet of medium density material. Smooth and takes a beating and will last well. Your local Home Depot o such will have this material.81H Venturer1100 "The Bentley" (on steroids) 97 Yamaha YZ250(age reducer) 92 Honda ST1100 "Twisty"(touring rocket) Age is relative to the number of seconds counted 'airing' out an 85ft. table-top.
Navel high or thereabout is a good general rule of thumb for a stand at bench, or about the same height as the "workbench" at the local watering hole'78 E "Stormbringer"
Originally posted by WMarshy View PostIve made plans to build a nice work bench in my basement - - - a magic number that seems to work well for your height? - - -
Set the bench top height so as to put the vise jaws at the exact level of your bent elbow when you are standing upright.
That allows you to hacksaw at stuff without stooping.Fred Hill, S'toon
Bench height should be tailored to the individual. You should be able to work comfortably while standing without bending your back, and without overstretching to get to the other side. Set up some boards on some drums or similar and experiment to get a height your comfortable with.1980 SG. (Sold - waiting on replacement)
ive used an old laminated kitchen bench top
that works well.pete
new owner of
08 gen2 hayabusa
former owner
1981 xs1100 RH (aus) (5N5)
zrx carbs
18mm float height
145 main jets
38 pilots
Put the bench together tonight, lookin good! Will have pictures tomorrow when I finish up the shelf underneath. Its definitely stout, not going to have a problem in that area.'79 XS11 F
Stock except K&N
'79 XS11 SF
Stock, no title.
'84 Chevy K-10 "Big Blue"
When I was in rehab for a low back injury I was instructed to set up working surfaces like this. It has worked well for me.
While standing in a comfortable stance with elbows bent so your arms are parallel to the ground, measure from the elbow to the ground and subtract 2 to 3 inches. That will work out to be a good working height for your bench top. Much lower then that and your low back will get sore. Much higher and you will be hitting your elbows on the bench. My bench is 37.5 inches high. My elbows are 42 inches off the floor when my arms are bent as described. It's not about how tall you are, it's how high off the floor your elbows are.
RobKEEP THE RUBBER SIDE DOWN
1978 XS1100E Modified
1978 XS500E
1979 XS1100F Restored
1981 Suzuki GS1100
1983 Suzuki GS750S Katana
1983 Honda CB900 Custom
That is interesting Rob. I know when I used to build golf clubs that most folks finger tips are about 27" IIRC from the floor. No matter how tall or short, 90% of the time that measurement will be the same.Life is what happens while your planning everything else!
MDF and masonite
Use a double MDF top glued together to make it 1.5" thick and spray glue a piece of masonite on it as a replaceable work surface. You could also glue the MDF to plywood.
The double MDF is strong - my vise is mounted in it and I beat the crap out of it without any sign of weakness.
JohnJohn is in an anonymous city with an Alamo (N29.519227,W-98.678980)
'81 XS1100H - "Enterprise"
Originally posted by DenyP View PostFavorite workbench!
DenyNathan
No... Apparently his wife does...1980 SG. (Sold - waiting on replacement)
Originally posted by b.walker5 View PostNo... Apparently his wife does...Nathan
