Ive made plans to build a nice work bench in my basement and after getting the top all ready to go on Im reconsidering the height at which to build it. Im about 6'2" so I was thinking the top should be between 40-46" tall... anyone out there got a magic number that seems to work well for your height? Bench is 32" deep by 8'...
Work bench, how tall?
'79 XS11 F
Stock except K&N
'79 XS11 SF
Stock, no title.
'84 Chevy K-10 "Big Blue"
"What they do have is an implacable, unrelenting presence and movement that bespeaks massive power lurking behind paint and chrome. They don't wail like a screeching ninja, the don't rumble like a harley. They just growl like a spactic, stressed out badger waiting to rip your face off and eat your soul." Trainzz~RIP~Tags: None -
Do you prefer to stand and work or sit and work? Are you going to have tools on the wall behind the bench?Nathan
Theodore Roosevelt -
most of my work will be done standing, if I choose to sit Im going to get a tall bar stool... I wont be hanging tools on the wall behind the bench as its just concrete block right now...'79 XS11 F
Stock except K&N
'79 XS11 SF
Stock, no title.
"What they do have is an implacable, unrelenting presence and movement that bespeaks massive power lurking behind paint and chrome. They don't wail like a screeching ninja, the don't rumble like a harley. They just growl like a spactic, stressed out badger waiting to rip your face off and eat your soul." Trainzz~RIP~Comment
I will go measure my bench in a little bit, but I want to say I have it somewhere around that height and I wish I had made it a little shorter. I would suggest measuring your kitchen counters, tables, and whatnot and compairing that height to what you are looking for.Nathan
Theodore RooseveltComment
Make it bar height
My bench is bar height or 42" above the floor. I am 6'-2" tall and work standing or on a bar stool. Height is perfect for everything you would normally do like building carbs or doing other small maintenance stuff. My vise is mounted on one end and the height of the jaws is good and my grinder and polisher is on the other end.
Working on something large like say, a motor, then table height or 36" seems to be a bit better. When I do this (rarely) I use the heavy table I usually keep my tool box stationed on. Also, this is a better height for something like mounting a drill press.
But in the end it is your specific preference.Mike Giroir
79 XS-1100 Special
Once you un-can a can of worms, the only way to re-can them is with a bigger can.Comment
Thanks for the advice guys, I already know the counters in my house are at 32" (34?) tall and think they are always too short. When I sketched up this work bench I planned on making it 42" but then last night I notched my 4x4 corner post and left it long to see if maybe I would like it taller... at 45" tall it was definitely too tall. Figured I would try and see what a common height was for people 6'+.'79 XS11 F
Stock except K&N
'79 XS11 SF
Stock, no title.
Got pictures? I'd be interested in seeing how people framed theirs...I will post a few when Im done.'79 XS11 F
Stock except K&N
'79 XS11 SF
Stock, no title.
I am 6 foot and my bench is 42" high and 31" deep. I do like the working height BUT it is a bit of a reach at times if something has rolled to the back against the wall.
I used all 2x4's for mine
Stock except K&N
'79 XS11 SF
Stock, no title.
I had 2 32"x60"x2" butcher block tabletops that I used.Nathan
Mine is 34" tall. I'm 5'10", and it's perfect for standing work. I dropped one end on it to allow the top of the bench to be a guide table for my mitre saw. All 2X4 contstruction, with 2X12's on the top. I trimmed the sides of the 2X12's so they would meet flat against each other (a poor-man's jointery). The feet are 3/8" bolts held into the bottom of each leg with Tee nuts, allowing me to level the bench. I mortised/tennoned the 2X4's to frame the bench, and mortised in a piece of plywood on the ends to keep things from falling out the end. The only fasteners I used are glue and drywall screws.
-H. FordComment
I'm 6' too, and I know what you mean about low counters...
It depends on how you're planning on using the bench. If you're only going to do 'light' work or work on small items, a higher bench is OK. But if you want to do 'heavy' work, don't go too high; if you're trying to grunt something heavy up onto or off of it, the extra height isn't a help. I like the top just above my belt buckle. And if you're going to mount a vice or bench grinder, the extra counter height can put those too high. If you're doing any grinding/drilling, the extra height just puts that stuff closer to eye level and that's not always good.
Make your countertop as stout as you can afford. While the base framing is important, if you do any beating on 'stuff' that will transmit the blows better. Using 1" plywood, I'd double it to 2". I'd also put some 1/4" hardboard over the top of the plywood as it will wear better and clean much easier. Use the extra hardboard to put a 4-6" backboard on the sides of the bench that go against the wall so you don't lose stuff in the gaps, and that will also help keep any spills on the bench. Slap a coat of some sort of sealer on the countertop as that will help it from soaking up the inevitable spills/fluids. Yeah, it'll get worn off in places, but it still helps.
I've got mine at 38", and that's about perfect for me. I certainly wouldn't go over 40". I was lucky, I salvaged commercial-grade all-metal cabinet bases for mine, and my benchtop is made of 1.5" solid-core hardwood doors (also salvaged). It'll support anything I can manage to get up there...Fast, Cheap, Reliable... Pick any two
Workbench?
This one works great. It's got adjustable legs for height. It's portable so you can take where the work is instead of bringing the work to the bench. If you need more work space, you can just get another one. When your work is done, you can fold it up and put it out of the way!
YesI'm trying to convince myself how well I have it.
Bob1979 XS1100FComment
My next question is, what are you using for audio in your shop?Last edited by WMarshy; 04-22-2011, 11:00 AM.'79 XS11 F
Stock except K&N
'79 XS11 SF
Stock, no title.
Audio? Who can hear over the grinder/drill press/welder/lathe/compressor?One of these days I'll pick up some used speakers that can take the power of the 200 WPC Crown amp I have in a closet, but until then the tools workin' are music to my ears...
