The plan
I was always taught to respect my elders, but it keeps getting harder to find one. -
Simply put, octane relates to the flash point of the fuel. It has nothing to do with energy content or burn temperature of the fuel. Using a higher octane in an engine that doesn't have either variable timing or a compression ratio suited for that high of a fuel grade is a waste. The combustion of the fuel will be less efficient.'79 XS11 F
Stock except K&N
'79 XS11 SF
Stock, no title.
'84 Chevy K-10 "Big Blue"
"What they do have is an implacable, unrelenting presence and movement that bespeaks massive power lurking behind paint and chrome. They don't wail like a screeching ninja, the don't rumble like a harley. They just growl like a spactic, stressed out badger waiting to rip your face off and eat your soul." Trainzz~RIP~Comment
Not sure where you got your google links, but it doesn't match either what I was taught in auto shop or in chemistry (mine was a few years before yours, OR what I find on google).
Here are a few links.
http://www.straightdope.com/columns/...nd-regular-gas
as i stated "i can possitively say that the octane rating is not relative to the energy content of the fuel, an octane ratings is better described as anti-knock rating since that is the pupose of it anyway"Daily Driver - '04 Suzuki Marauder 1600
Project Bike - '79 XS1100 Special
Hi my name is Nate and I'm am Addict...I quit riding every night before bed and can't help but start riding again the next morning...
Ride Till You Die!
"MESS WITH THE BEST DIE LIKE THE REST" -Semper Fidelis!
“Most motorcycle problems are caused by the nut that connects the handlebars to the saddle.”
"When in doubt, Gas it!. If it doesnt fix the problem, at least it will end the suspense!"Comment
its official!
gas octane threads are now in the same category of Hot Button topics as which oil is best, which tire is best, and what's better: Special or Standard
Everybody knows the BEST gas is the one YOU decide to put in your tank.
John
Now do I need to bring Mr King into this discussion?John is in an anonymous city with an Alamo (N29.519227,W-98.678980)
'81 XS1100H - "Enterprise"
"Not all treasure is silver and gold"Comment
John
CY, it just occured to me that i think we are saying the same thing...so heres what i think u are saying...the higher the octane the slower it is to combust therefore the higher the temperature must be to put the fuel at a point where it will combust therefore running your vehicle motor at a higher temperature...the fuel itself does not burn hotter, however it does take a higher temperature to get that fuel to combust...
BINGO I GOT IT I THINK...Dont i?Daily Driver - '04 Suzuki Marauder 1600
Ride Till You Die!
John
Now do I need to bring Mr King into this discussion?Nathan
Theodore RooseveltComment
Hi performance engines don't get their power from hi octane fuel but from the components and design of the engine. Using it when not designed to require it will not produce more power, just waste money and fuel.
79SF
XJ11
78EComment
Trying to quiet a disagreement is often a good idea . But not when it lets ignorance feel justified.
http://www.ftc.gov/bcp/edu/pubs/cons...tos/aut12.shtm
and the reason i say not completely correct is because using all of my vehicles a truck, van, camaro, 2 motorcycles as well as 2 four wheelers, i had deduced that most vehicles would also increase power and fuel economy as did mine...which is not the case...and i gather that the reason that all of mine do is because all but one of them are built around performance with high compression ratios...like my 2 quads are both built for racing, my bikes are built for high performance, my truck has a high compression ratio, though it still recommends low octane which i do use most of the time until i'm hauling my trailer in which case it is running harder and the higher octane actually helps me improve my mileage, though i often times still tow with the low octane fuel - cause its cheaper - but i know it improves the mileage because i've used both on cross country trips hauling the same load both ways both with oil changes before hand and after with the higher octane i got 13 mpg and 10 mpg with the low octane...which is the average over 2800 mile drives...and my van is on the older side of things and therefore the higher octane helps smooth the engine out which in turn improves my fuel mileage in that, and of course my camaro is also high performance...so i'd like to apologize again if anyone was offended by my ramblings...but i do it to learn and i find it amusing...Daily Driver - '04 Suzuki Marauder 1600
Ride Till You Die!
Ride Till You Die!
john, tiz true...
BINGO I GOT IT I THINK...Dont i?Cy
I'll also mention, my Camaro (when it was running) got better mileage on mid grade or premium, but only marginally, and not enough to justify the extra cost, it still ended up costing more per mile to run premium than to run regular. But that is because the knock sensor allows it's high compression engine to adjust to the fuel. Some modern bikes can do this as well, and some of them require mid grade or premium gas and if they do, you need to run that.
Just remember, the higher octane fuel does NOT run cleaner, so, don't just go on you getting a couple MPG better, check your $ per mile, cause unless the higher grade LOWERS it, you ARE wasting your money if the vehicle doesn't require the higher grade gas, in addition, the higher temps the engine will run because of the longer time the flame front exists in the cylinders will also lower engine life by increasing stress on the internal parts.
So yes as you said, the premium fuel may burn slightly cooler (and it it's just slightly cooler) but it does so longer, and so it actually generates more heat because of this. And unless the vehicle can take advantage of being able to advance its timing so it's not throwing unburnt fuel out the exhaust, at best mileage will stay the same, at worst it will go down (my XS11 goes down on premium significantly and just slightly on mid grade). As a matter of fact, if I switch to mid grade or premium fuel, I have to turn my idle speed up because it slows down by about 50-100 RPM. Now of course Ca gas is crap anyways, so that makes it FAR worse, so real gas is likely not as bad (as a matter of fact I don't recall things being as touchy back in the day), but I've gotta live with what I gotta live with.Cy
Slight reword, since it burns slower, it takes longer to burn, exposing the internal parts to the flame front for a longer time period. This is not as much an issue for a water cooled engine, but for an air cooled engine which may be on the edge of overheating in come conditions already, it can be the difference between melting a piston and just making it home under the line. I'm not going to subject MY engine to the additional heat when it's NOT going to give you more power unless you have increased the compression of the engine enough to require it. BTW, while these bikes say 91 octane, that was based on a different formula than is used now, and what is called 87 octane now is typically right about what they were talking about back then as 91 octane.I'll also mention, my Camaro (when it was running) got better mileage on mid grade or premium, but only marginally, and not enough to justify the extra cost, it still ended up costing more per mile to run premium than to run regular. But that is because the knock sensor allows it's high compression engine to adjust to the fuel. Some modern bikes can do this as well, and some of them require mid grade or premium gas and if they do, you need to run that.
So yes as you said, the premium fuel may burn slightly cooler (and it it's just slightly cooler) but it does so longer, and so it actually generates more heat because of this. And unless the vehicle can take advantage of being able to advance its timing so it's not throwing unburnt fuel out the exhaust, at best mileage will stay the same, at worst it will go down (my XS11 goes down on premium significantly and just slightly on mid grade). As a matter of fact, if I switch to mid grade or premium fuel, I have to turn my idle speed up because it slows down by about 50-100 RPM. Now of course Ca gas is crap anyways, so that makes it FAR worse, so real gas is likely not as bad (as a matter of fact I don't recall things being as touchy back in the day), but I've gotta live with what I gotta live with.Daily Driver - '04 Suzuki Marauder 1600
Ride Till You Die!
Hijacked thread
The Plan was originally about planning for a long trip. Nothing about what gas to use.... As for what gas, just remember these engines were designed for regular gas. That's what I use, it serves me and the bike well. You will be hard pressed to find one that runs better than mine. 'Nuff said.You can't stay young forever, but you can be immature for the rest of your life...
Drilled airbox
Tkat fork brace
Hardly mufflers
late model carbs
Newer style fuses
Oil pressure guage
Custom security system
Stainless braid brake linesComment
The Plan was originally about planning for a long trip. Nothing about what gas to use.... As for what gas, just remember these engines were designed for regular gas. That's what I use, it serves me and the bike well. You will be hard pressed to find one that runs better than mine. 'Nuff said.Nathan
