View Post
A Venting Thread!!!! FORD SUCKS!!!
Not goin' there Steve.........HBT and all, but at times seems engineers and reality do clash......81H Venturer1100 "The Bentley" (on steroids) 97 Yamaha YZ250(age reducer) 92 Honda ST1100 "Twisty"(touring rocket) Age is relative to the number of seconds counted 'airing' out an 85ft. table-top.
Originally posted by CatatonicBug View PostYeah... I'm not a fan of the Supers or the Buses. I DO like the Things though. That would be my ultimate fun car. Unfortunately, all I've ever found are rust buckets.
The '71 is more Beetle than Super, as it still has the flat windshield/dash. It does have that funky 'fresh air' intake, but I removed all that (had to fill something like 16 holes in the dash after removing!). The strut front suspension is an improvement over the torsion bar but more expensive to fix. Still have to rewire it for towing (VW used a left/right lighting setup instead of front/rear), but the weight is now low enough that I don't need to tie the brakes to the MH. With the added ground clearance from the weight loss and a set of snow tires, I figure it will have a bit of 'off-road' capabilty.Last edited by crazy steve; 12-03-2010, 01:47 PM.Fast, Cheap, Reliable... Pick any two
%$#& Ford
The last decent ford engine was a flat head V8--------that is until you had to re-adjust the valve lash. I hate every bolt on a Ford.put something smooooth betwen your legs, XS eleven
79 F (Blueballs)
79 SF (Redbutt)
81 LH (organ donor)
79 XS 650S (gone to MC heaven)
76 CB 750 (gone to MC heaven)
rover has spoken
Originally posted by rover View PostThe last decent ford engine was a flat head V8--------that is until you had to re-adjust the valve lash. I hate every bolt on a Ford.Fast, Cheap, Reliable... Pick any two
This is how a v-6 Passat looks when you change the alternator
1980 LG
1981 LH
Yeah even VW has gone off the deep end!!!
This is by far not my first problem like this. I had an 88 Toyota truck and it took me ten minutes to get the starter off the engine and then two hours to get it off the truck only after removing the solenoid from the starter. So, another 20 min job that took 3 hours.
I just have never hear do such insanity as needing to drain the flipping coolant from the engine to change starter. Especially when it is such a long repetitive process to refill the bloody thing. That turned into another 3 hour process of filling the overflow, getting the engine to temp to open the thermostat, let it cool, refill overflow....repeat......repeat....repeat.....repea t!! What ever happened to a radiator cap you can pull, fill the thing up. Run it once to let the thermostat open and then top it off and be done.Life is what happens while your planning everything else!
Duh. Cant sell them so you have to make money servicing them. The whole issue is that the manufacturers have to make sure you and I can not service or rebuild them. They lose so much money that way!2-79 XS1100 SF
2-78 XS1100 E Best bike Ever
And people scoff at my 68 F100 with 240 ci straight six. Top-loader 4 speed with granny low. It smokes and rattles a bit but still going strong and easy to work on. I can remove the starter from the top or bottom, either way works. I could probably remove it with the truck running.Pat Kelly
<p-lkelly@sbcglobal.net>
1978 XS1100E (The Force)
1980 XS1100LG (The Dark Side)
1999 Suburban (The Ship)
1994 Dodge Spirit (Son #1)
1968 F100 (Valentine)
Originally posted by Pat Kelly View PostAnd people scoff at my 68 F100 with 240 ci straight six. Top-loader 4 speed with granny low. It smokes and rattles a bit but still going strong and easy to work on. I can remove the starter from the top or bottom, either way works. I could probably remove it with the truck running."If A equals success, then the formula is: A = X + Y + Z. X is work. Y is play. Z is keep your mouth shut." - Albert Einstein
1980 LG
1981 LH
On the brighter side of things, last night I changed the serpentine belt on my F150 witht he 5.4L V8. Entire process took less than 30 minutes. And a good deal of it was spent getting my daughter out to the garage, who is now driving it more than not, so she could push the ratchet to loosen the tensioner while I put the belt over the alternator pulley with both hands.
MY brother had a Dodge Dakota which had an inline 4 in it. Now that thing was worthless. Barely got out of its own way and even then, they still had one spark plug shoved in behind the AC compressor!!Life is what happens while your planning everything else!
Yeah, changing the belt on my Camaro takes a 1/2 inch drive ratchet, and pretty much one other hand (the hard part is getting it routed right).
However, my 2003 Malibu requires removing one motor mount to change the belt. At least they actually made it easy to get the motor mount out for that. Now I haven't changed the plugs yet, I'm only 10k over when I was supposed to change them at 100k, but I think I have to disassemble a bunch of stuff to change the back 3 (the front 3 are pretty easy).
I did have the water pump go out and it was easy, but the spark plugs seem less than easy, although only needed every 100,000 miles.Cy
I bought a 91 Dodge Spirit new. It had the v-6 and 4 spd tranny. The tranny quit just before the warranty went out. After that, no repairs until I sold it at 200K miles. At that time the valve stem seals were starting to leak a bit. I drove the car from St. Louis area to Mpls about 4 times a year, and one a year to New Orleans once a year. Thats why in 9 yrs it had the 200K on it. On the freeway it always averaged 33 mpg. Around town about 28 mpg. Now I have a 2000 toyota Camry with a v-6. Best mileage on the freeway is 30 mpg and 25 around town. Nine years newer and less gas mileage. And on TV chevy and other car companies are boasting 28 mpg. My, how technology has improved our lives!!! Biggist mistake I ever made was selling the Dodge. The Toyota needed a new thermostat. $10 at Autozone. About 20 minutes to coax the old one off, and 2 hrs to get it out.
Wonderful!
Ole JackJ.D."Jack" Smith
1980G&S "Halfbreed"
1978E straight job
"We the people are the rightful masters of both congress and the courts, not to overthrow the constitution, but to overthrow the men who pervert the constitution." Abraham Lincoln
Life is like a coin, you can choose to spend it any way you wish, but you can only spend it once. Make your choices wisely.
Just to chime in on this one.....I've been servicing cars/trucks for a living for a quarter centuryn now and have dicovered one truism, that appears valid across all makes and models, that explains why they are so maddeningly frustrating to reapair at times: they are designed and engineered to be ASSEMBLED, not serviced.'78 E "Stormbringer"
Originally posted by ManagerMike View PostJust to chime in on this one.....I've been servicing cars/trucks for a living for a quarter centuryn now and have dicovered one truism, that appears valid across all makes and models, that explains why they are so maddeningly frustrating to reapair at times: they are designed and engineered to be ASSEMBLED, not serviced.There are only two types of bikers...
those that have layed it down, and
those that have not layed it down...YET!
1982 XJ1100J Maxim (F-Bomb)
Not going to lie, Brand new at this... thanks for having a bit of patience with dumb questions
