One click too far
    One click too far
    My son phoned, his bike wouldn't start after he'd parked it overnight and used the steering lock for the first time ever so it'd be more stable on the sidestand with a cover over it.
    "One click too far!" I cried.
    "Duh?"
    "The last little leftward click on the key turns on the rear light, you have run the battery flat."
    "What (expletive deleted) genius dreamed that up?"
    "It's a safety feature."
    He then used combinations of bad words in denigration of that feature that amazed me, followed by "Can I borrow your battery charger?"
    I told him, "Yeah, sure. It could have been worse, you could have been 200 miles from home like I was when I did it."
    So, how many have actually used the lock+parking light feature on purpose, rather than running the battery flat by accident?
  • b.walker5
    • Feb 2009
    • 1745
    • Invercargill, New Zealand
    Not me. I've never managed to get the bloody steering lock to work, let alone the park light feature....
      Never here either Fred. Although I have not run the battery out, I did manage to leave it on once during a short stop. Came out and saw it on and from then on watch it like a hawk when locking.
      Brian, I was recently rebuilding a lock and found that the orientation of the locking cylinder when inserted effects if the lock feature will function. So, if someone has been dorking with your lockm that may be the cause of it.
      • TADracer
        • 1417
        • Kenner, Louisiana USA
        I left it on overnight once a long time ago. Now I am in the habit of passing my hand by the rear light while I walk away so I can see a red glow if I went too far.
        Mike Giroir
        79 XS-1100 Special
        • XSive Okie
          • Jun 2010
          • 281
          • Enid, OK
          I have never used the steering lock at all, live in small-town Oklahoma where not too many people mess with your stuff.
          Richard
          '79 XS1100SF "Phantom Stranger" full fairing w/radio and cd player, H-D Roadking trunk, everything else stock
          '02 Honda VTX1800C
          • psycoreefer
            • Feb 2008
            • 1557
            • Minden, NV
            I turned my key to park once, after cleaning the ignition switch, just to see if it worked. Other then that I never use the park, or lock, positions.
            SWMBO on the other hand has some sort of obsessive compulsive disorder when it comes to "locking" things. When she rides she always uses the lock position, I've tried to convince her that no one wants to steal our crappy old bikes, and if they actually did want it having the steering locked wouldn't stop them.
            1979 xs1100 Special -
            My Bike:
            [link is broken]
            • BigRed
              • Mar 2010
              • 265
              • Ottawa, Ontario, Canada
              I use the steering lock when I park at work, but never the light "feature". I was lucky the first time when I turned one click too far, as I was in a parking garage, so the light was obvious. I first thought my brake light was stuck on, but then figured out what the problem was.
              • bchaffin
                • 47
                • Warrensburg, Missouri
                I did it when I first bought my bike. Left it on for almost 8 hours, turned the key foward and it still started. I got lucky.
                1980 Yamaha XS1100 Std
                4 into 1 exhast, pod filters
                2003 Triumph Thruxton
                • Ivan
                  • Jul 2008
                  • 2524
                  • Hutchinson KS
                  I have. Now when I use the lock, I walk around to the back of the bike and make sure the light isn't on, since there is no real detent between lock and park.
                  Ich habe dich nicht gefragt.
                  • Poprock
                    • Apr 2005
                    • 594
                    • Oregon Coast
                    I always turn mine hard left, then back one click. So far that's worked. The label thingy is gone, so I had to learn the count.
                    • petejw
                      • 2269
                      • sydney australia
                      my first road bike was a 78 xs250 back
                      in 82 it has the same ignition set up as
                      its bigger brothers, i did it on that bike,
                      but havent on the 11.
                      pete
                      new owner of
                      08 gen2 hayabusa
                      former owner
                      1981 xs1100 RH (aus) (5N5)
                      zrx carbs
                      18mm float height
                      145 main jets
                      38 pilots
                        • 6765
                        I never knew this... Gawd thats embarassing...27+ yrs of ownership and I just learn this now Is this feature on my '82 XJ ?...if it is I have never seen it on...then again I cant even recall ever using the lock feature...Just yesterday I did try to get the lock to work to no avail.
                        2005 Honda SilverWing 600
                        2018 Honda PC-Xpress 150
                        • mstic2000
                          • Aug 2008
                          • 574
                          • Saginaw, Mi
                          I've turned it to the parking light a few times by accident but never left it to where the battery went dead. First time I did it I thought, "Now what prompted someone to add this feature?" There's gotta be a story behind it.
                          My 1978 http://img.photobucket.com/albums/v518/mstic2000/xs.jpg
                            • 8938
                            I always figured that feature was there so if the bike broke down on the side of the road at night, you could lock it to prevent it from being stolen while going for help, and having the marker lights on so no one ran the focker over.
                            I use the lock on my SF because I leave it outside, but the lock is a little worn so it won\'t make it to the light on position. On my F, the lock position is disabled because of the FJ triple trees.
                            • kjohnson
                              • Aug 2007
                              • 202
                              • Wetaskiwin, Alberta, Canada
                              The XJ has a separate lock on the steering neck to lock for parking, but I think there are also positions on the ignition for park lights. Neither seem to work on my XJ the last time I checked.
                              K. Johnson
                              -1978 XS750SF - brought back from the dead with carb
                              triple clean and boots
                              -1982 XJ1100J - brought back from the dead by
                              replacing motor after throwing #4 rod
                              -1985 XJ750XN - shim job, oil change, ride. not bad for
                              $500 including new rear tire.
