Ok, long story short SWMBO and I and our son got stuck "off road" last weekend to the tune of an 800 tow bill, so I decided it was time to look for a winch "just in case" ya know. I found one on craigs list for 30 bucks, but it's broken. I got it anyways because the solenoid, cable, hook, motor, ect are all good, and I think it can be repaired.
So the question is, how would you guys recommend fixing this thing. Bellow are pictures. The best I can describe is the free spool lever is "supported" by a hole in the end cap of the case, that hole has "broken" and allows the free spool lever to have too much slop. The lever rotates left and right to lock the outer part of a planatary gear set to the case. Hopefully the pictures will show what I'm trying to describe.
The lever in question - its not broken
The broken hole in the end cap of the case.
Cap removed from the case, note the broken edge of hole
The other side of the same part
Another view
And a view of the gear box showing the hole in the top where the free spool lever rotates to lock the outer gear to the case.
My first thought was to fill the hole with JB weld and then re-drill the hole, but I'm not sure that would be the strongest, best way to fix it. Thanks for your input guys.
And in case anyone is intersted a shot of the whole deal
Another view
