Farmall C
  • red bandit
    • 950
    • central michigan
    Farmall C
    Anybody know what to torque the head down to on a Farmall C? Any torque charts per bolt size? It has 1/2" fine thread studs.
    79 F full cruiser, stainless brake lines, spade fuses, Accel coils, modded air box w/larger velocity stacks, 750 FD.
    79 SF parts bike.
  • rpgoerlich
    • Dec 2007
    • 643
    • Katy, Tx
    I found this: http://www.ytmag.com/farmall/messages/328352.html
    And this for a Series A-B-C Farmall:
    CYLINDER HEAD
    Series A-B-C
    30. To remove the cylinder head,
    first drain cooling system and remove
    hood, valve cover, rocker arms assembly
    and push rods. Loosen upper
    radiator hose and disconnect the combination
    fan bracket and water outlet
    casting from head. Disconnect fuel
    lines and remove carburetor and manifold
    assembly. Remove the cylinder
    head retaining stud nuts and lift cylinder
    head from tractor.
    When reinstalling cylinder head,
    tighten the stud nuts evenly and to
    a torque of 65 ft.-lbs.
    Richard
    • XS1100 Newbie
      • Jun 2009
      • 1106
      • Battle Ground, Washington
      And i found this.
      1980 XS1100LG Midnight
      1991 Honda CBR1000F Hurricane
      A cold beer and another one!
      • red bandit
        • 950
        • central michigan
        Thank you very much!
        79 SF parts bike.
