...and being entirely self-taught, I lack the book knowledge and experience that somebody that is or has done it for living would know. So, what exactly constitutes an 'interference fit'? I want to press an aluminum 'plug' into a hole so I can re-drill it offset a bit. The part I'm pressing into is also aluminum and a casting, so I don't want to break it. Or would I be better off with a 'light' fit and 'pinning' it for retention and/or to prevent rotation?
TIA!
'78E original owner
TIA!
'78E original owner
) smaller than the shaft so it must be pressed on.
. Hmm, so you don't think the plug would hold with the hole offset that much. I'm only going to be into the original hole about .050". How about if I pinned the plug at two points 90 degrees to the 'break-through'? To get any TIG done means a long drive and money out of pocket, so I'm trying to avoid that, cheap-a$$ that I am.
