Just bought another RCBS reloading press and I want to mount it a portable foldup type setup. Thought about one of those Black and Decker workmate benches but wonder if it would be strong enough to take it. Anyone doing this ?? Any suggestions ??
Any reloaders amongst us ??
"A man should look for what is, and not for what he thinks should be" Albert Einstien.Tags: None -
That seems to be fine for now but you will find that it will be too unstable. I mounted my RCBS to a small piece of ply wood that I clamped to my bench when I needed to use it tucked it under the bench when it was not in use.BDF Special
Dyno tuned to 98 hp at the rear wheel. -
Don't know how heavy those workmates are but I think you will need something with a little more weight to it.79 F full cruiser, stainless brake lines, spade fuses, Accel coils, modded air box, 750 FD.
79 SF parts bike.Comment
Hi Brian,
the big B&D Workmate* should be sturdy enough for use as a portable base but with a reloading press bolted on to it the folded Workmate wouldn't be flat but a kinda L-shape. You'd have to hold the press on with clamps and remove it to be carried separately (along with all the other reloading stuff) if you were going someplace to reload.
*their largest model and a real B&D unit not an el-cheapo copy.Last edited by fredintoon; 04-13-2010, 09:55 AM.Fred Hill, S'toon
"The Flying Pumpkin"Comment
I think
Fred, as usual, has a good idea. Having four well spaced legs is important especially when running your brass through the sizing die. If Fred's picture of a L shaped folded package is not what you want, maybe you can just clamp the press on the B&D and remove before folding. That would mean two pieces, but should be doable.
Ole Jack.
You could add a third item, a hard side briefcase to hold dies, powder, primers, and various other item. Oh, yes a powder measure or scale.J.D."Jack" Smith
1980G&S "Halfbreed"
1978E straight job
"We the people are the rightful masters of both congress and the courts, not to overthrow the constitution, but to overthrow the men who pervert the constitution." Abraham Lincoln
Life is like a coin, you can choose to spend it any way you wish, but you can only spend it once. Make your choices wisely.Comment
A workmate should be more than strong enough. My reloading bench is a center out of a pedestal type kitchen table and it has about the same footprint and works fine. I have a very old RCBS Rockdchucker on one side and a Dillon RL550B across from it and I plan to bolt up shotgun presses on the other 2 sides...
GeezerHi my name is Tony and I'm a bikeoholic.
The old gray biker ain't what he used to be.Comment
Mounting table
Try mounting the press to a ply or preferably MDF top larger than the top of the workmates. Underneath the top screw a 4x4 lengthwise that can be easily clamped in the workmates to work and removed. This way the workmates can still be used for other stuff too.
Mine is setup sorta that way though I have it mounted on top of a small rolling tool chest add-on and store powders in the chest.
John in San AntonioJohn is in an anonymous city with an Alamo (N29.519227,W-98.678980)
'81 XS1100H - "Enterprise"
"Not all treasure is silver and gold"Comment
Now. thats a good idea...
Thanks for the ideas guys, I think it's definately worth a look at a workmate for a portable "field" rig. Fred, I take your point about the "real" B&D bench. There are lots of cheap copies around that are just crap. I'm not keen on the clamp option because as Ol' Jack pointed out, a fair bit of force is required when sizing brass and good stability is a must. I already have the rest of the gear in a case so thats not a problem. I've had an RCBS Partner press permanently bench mounted for years now and now I want a portable setup with a good press that I can throw in back of the truck when on hunting trips. I could have bought one of those little hand load things but I dont like them much.Try mounting the press to a ply or preferably MDF top larger than the top of the workmates. Underneath the top screw a 4x4 lengthwise that can be easily clamped in the workmates to work and removed. This way the workmates can still be used for other stuff too.
John in San Antonio
Tinman, if your prophecy about instability comes true, then at least by using Johns suggestion I'll still have a usable bench for other stuff.
Thanks All.1980 SG. (Sold - waiting on replacement)
"A man should look for what is, and not for what he thinks should be" Albert Einstien.Comment
Just a thought.I like to be able to stand up strait when I'm using the press and sit down when I'm weighing,trimming etc..If I have to bend over while I'm using the press my back starts hurting very quickly.I built my bench to bar height and then have a stool to sit on. Terry1980 special (Phyllis)
1196 10.5 to 1 kit,megacycle cams,shaved head,dynojet carb kit,ported intake and exhaust,mac 4 into 1 exhaust,drilled rotors,ss brake lines,pods,mikes xs green coils,iridium plugs,led lights,throttle lock,progressive shocks,oil cooler,ajustable cam gears,HD valve springs,Vmax tensioner modComment
