Just a rant!!!!
  • Filter
  • Just a rant!!!!
    Rode my XJ650 yesterday, and got really po'd when i realized that it ran through the rpm range twice as good as my XS11. I guess the only reason that this bothered me so much is that if i could get the XJ650 to run this well, then why the heck can't i do it to my XS11. The 650 will run right up, and over the red line without missing a lick, but the 1100 has trouble going over 5000. I'll get that sucker right yet, or i'll ride the 650.
    1980 XS1100LG Midnight
    1991 Honda CBR1000F Hurricane
    A cold beer and another one!
  • #2
    Hi Robert,
    if you've done all the "make it go properly" tricks to be found here to no avail, try psychology.
    Ride the XS11 to the scrapyard and ask it:-
    "Wanna go in and see the crusher?"
    • #3
      Check and adjust valves, Clean and sync carbs ...! Two cylinders are much less touchy. Get her right and you will forget you own a twin.
      Deny
      • #4
        Don't own a twin. YUK It is an inline 4 650. Fred you might have a good idea there. Might scare the thing. Maybe that is it's new name. "THING"
        • #5
          Just got through pulling my carbs again. I reset the float level at 23MM, and rechecked the wet level. The level is just about perfect. I had to raise the floats quite a bit, and figured that the wet level would be way off. Made me a gauge out of a credit card so it would span both sides. Worked great for float setting. Best use of a credit card i ever saw. LOL Will reinstall carbs tomorrow, and test. Keeping my fingers crossed.
          • #6
            checking float levels upside down.....
            hey there xs1100 newbie......not all is as it seems in XS land...don't believe the manual or bad ju-ju may curse you to the land of "no bikey runney-land".....do the carbs run upside down?!......H*LL NO!!!.....then explain to me why the procedure to check the float levels is that way......found a better way to check 'em out (more reliable as far as i'm concerned!).....here is the link to when i re-did the carbs on the "rebel devil".....
            http://www.xs11.com/forum/showthread.php?t=17116
            ....hope this helps and can give advice if u need....ride hard, ride safe.....ross
            rebel devil
            1979 xs 1100f standard
            authenic historical vehicle
            42°36'23.52"N, 82°52'44.78"W
            "I'M IN MY HAPPY PLACE"
            "i got 14 jobs mon....you only got 1 job....you lazy bones mon"
            "if you don't wrench on it, get behind me satan!"
            '96 venture cct.....installed!
            stainless, braided, pvc coated brake lines
            i can translate...deustch, nederlands, 汉语, 漢語, français, ελληνικά, italiano, 한국어, português, русско, español and most importantly, 日本語....
            • #7
              Hey Ross, he did the fuel level check. But rage on cause your right! Fuel level checks are superior, just got done doing mine tonight, should make a noticeable difference.
              I'm just throwing this out there and I'm more than likely very wrong, but I've read on another thread that if your slider needles are worn out, you can loose upper to midrange power. Again, I could be wrong, just something to look at while the carbs are off.
              If your carbs and valves are synced and adjusted right, maybe your vacuum advance is bad. It's pretty easy to check it with a vacuum gauge. Hook up your vacuum advance to a T, one tube goes to your mouth, the other goes to a vacuum gauge. Suck on the tube, plug with your tongue, and watch the gauge to see if it leaks down. Fred?
              • #8
                hey newbie and yard dogg,
                noticed both of you have the 80 model xs,
                i commented on your other thread yd,
                sounds like you both have the bitsa model carbs
                if your carbs are fitted with 110 main jets id set the carbs
                up using the later model specs,
                newbie, the bike should be flying after it hits 5000rpm,
                usually if it starts breaking down around then and you have
                no electrical problems the main jets are to big.
                what size jets are you using, are the needles adj on the carbs,
                if they are what are they set at, also whats your float heights set at?
                pete
                new owner of
                08 gen2 hayabusa
                former owner
                1981 xs1100 RH (aus) (5N5)
                zrx carbs
                18mm float height
                145 main jets
                38 pilots
                • #9
                  The jets are #110, and the needles are non adjustable on my 80. Refer back to post 5 to see yesterdays outcome on adjustment. Carbs will be back on today with any luck.
                  • #10
                    Bob can you get it to my place to work on it a day or two if needed?? there is something we are missing and all my tools and equipment are here I don't care if we have to resort to swaping out parts untill we find the problem. call or PM me. Larry R
                    Alias Larry R in Kelso WA
                    When in dought, punch it.
                    XS1100LG Precious current
                    XS1100SF Ruby gone to a better home
                    KZ900B MIA stolen (ALL bike thieves MUST GET OFF THE PLANET more politically correct ???)
                    • #11
                      We are working on the exact same bike! Like how exiting scooby!
                      I haven't run my bike with the massive main jets I ordered thinking they were 1 size up. My bike also has 110s and it ran great last year except for being a bit lean. I've never had the problem you are describing. I'm leaning more towards a timing issue, or ignition. But just in case it's carb related. Before you put the carbs back on, check your throttle slide diaphram boots for leaks.
                      • #12
                        Fred: I think psychology might have worked. Before i touched thing off this afternoon, i told it that if it didn't run right this time, i was going to trade it for a Honda. Fired Thing up, and went for a short ride. Runs up to 8500 no problem. Did sputter the first time though. I have not synched it again yet.
                        Larry: Thanks for the offer, and i might take you up on that. I would have to have my wife pick me up if something happened i couldn't ride it home, but that could be arranged. As i said above, i may have got it. I also cut some off each plug wire to get clean connections to be sure there. It now pulls hard even at 60 MPH. Wouldn't do that earlier.
                        • #13
                          congratulations....(hopefully)...
                          hey there xs1100 newbie....congrats on the savvy to fix the problem....see, the forum can help you fix almost everything (except when you call SWMBO the "c" word!!....you are one your own there!!!)......now if ya really got it right, ya should be able to show us a picture of you "showing off" like this.....
                          ....still workin' on it myself....ride hard, ride safe....ross
                          rebel devil
                          • #14
                            Bob glad to hear the monster has started acting like one. I should have mentioned that if we had not got it the first day I would take you home and get you back up here the next day.
                            • #15
                              Ross, i don't think i'll be doing that, but it does feel good to finally feel what the power should feel like. Besides, i can't even touch the ground with both feet flat on it, just my toes.
