Bought SS brake lines from coastguard1975 on Ebay. Just FYI I add the following emails.
Original to -Just wanted you to know the bike is a 1981 XS1100 Midnight Special. Do not know if that makes any difference.
First email after problem -
Hi,
I bought a set of your SS Brake lines for a 1981 Yamaha1100 Midnight Special thru Ebay on 12/15/2009. Now that it is warming up I am attempting installation. On pic #1 see the brake lines will work even though the ends are supposed to be 90. I can deal with that. On pic #2 please advise as to proper installation.
Pasted pic
ONLY Response from-
John,
I had sold many sets of these XS1000 brake hoses.
This is the first time this happened.
Is your 1100 same as XS1100 ?
Do you know if a "Special" is different than a "Midnight Special" model ?
Regards,
Raymond
Last to -
Yes, the 81 midnight special has many one of a kind parts. These two brake lines are only used on the 1981 Yamaha 1100 Midnight Special (1100LH). Obviously I can reuse the steel tubing on the one if I can get replacement ends. The other one is considerably longer. I am a member of XS1100 club where there is over 5000 members. A good guess is about 200+ members have this model as it is highly collectable. If you can do this hose then I will put you in as a accredited supplier. What can you do for me? I have the bike tore down and installed the two lines I could get to work. I do not want to go back in with the old lines and riding weather is upon us. Would it help for me to send the two that won't work? I would send you all 4 so you could get an exact kit together. I can get them out today if you want.
Thanks,
John
I'm thinking this guy has one style and is pushing it as fitting everything.
What was your experience with him?
Hi,
Pasted pic
ONLY Response from-
John,
Regards,
Raymond
Last to -
Thanks,
John
) all ends are turned the right direction and the banjo's are the same thickness as original.
