gold valve emulators...
  • yamahansolo
    • Aug 2007
    • 1113
    • jawga
    got em in the mail 2 days ago!!! yeah!!!
    only i got several pages worth of directions and i have no idea which to use... also it says i need an adaptor but the website didn't say anything about needing one. also it didn't say i needed 15 wt fork oil and i had just bought 10 wt about 2 weeks ago.
    the papers that came with them says to use 15... any body have any ideas? i am also going to try to write the racetech guys to get some info from them. thanks
    79 xs11 standard
    8mm msd wires
    tkat fork brace...
    Fox shocks...
    mikes650 front fender
    led's gallore...
    renthal bars
    vmax tensioner
    Rifle fairing
    RaceTech sends out multiple directions with all their emulators, so yeah, it can get confusing. Use the ones closest to what you have. The adaptors are only needed if the emulators don't 'seat' into the top of your stock dampers. They should fit fairly snug, but just a bit of looseness is ok. If you do need adaptors, don't try getting away without them. The bottom of the springs should fit the top of the emulators about the same. As to the 10 wt oil, it should be fine. My experience with them is if you use all their recommendations the front ends up pretty stiff which is great for the track but not so good for the street. The critical thing seems to be getting the spring pre-load right; here I'd follow their directions to the letter.
    '78E original owner
    • Mathh
      • Nov 2006
      • 697
      • Beek, Netherlands
      '78E original owner
      Yup, I used 10wt oil as well in my project forks. And for the pre load: it is possible you have the forks again to modify, that is the only nagative thing with these things. As I said earlier I use the YSS ones and mentioned they are cheaper. That is correct for retail but not for the customer himself
      Overhere these valves are a succes with classic racers because you can't see any modification on the outside.
      MV Agusta Brutale 910R '06.
      Yamaha MT-09 Tracer '15 grey.
      • yamahansolo
        • Aug 2007
        • 1113
        • jawga
        the adaptor i mentiond sits on top of the spring it self not the emulator???
        79 xs11 standard
        8mm msd wires
        tkat fork brace...
        Fox shocks...
        led's gallore...
        renthal bars
        vmax tensioner
        Rifle fairing
        • WMarshy
          • Apr 2009
          • 2402
          • Mexico NY
          Currently, I dont know much about the forks and how their all assembled and exactly how they do their black magic, but this might help you some. I guess once I do the FJ fork mod I will be some what knowledgeable about the subject.... Scroll 3/4 the way down for pictures/example of the emulators.
          '79 XS11 F
          Stock except K&N
          '79 XS11 SF
          Stock, no title.
          '84 Chevy K-10 "Big Blue"
