i appreciate all that responded to my last computer questions, but thought i'd start a new thread for the latest problem:
i know i need more ram so
i'll explain EXACTLY what i did, and the results;
1. shut computer off and disconnected all the cables.
2. set on table, put on esd strap and opened cover.
3. located ram card, removed it and copied the numbers from it to aid in ordering another
4. noticed it was very dirty inside and thought it should be cleaned.
[the fan was real filthy and the onlyway to remove the fan is to remove the cpu and the heat sink connected to it.]
5. i rmvd cpu and heat sink.
6. rmvd fan assembly
7. cleaned all parts mostly by hand and using a little key board brush.
8. reassembled and reconnected cables [inside and out]
9. fired it up and got NOTHING BUT FAN.
no monitor
no keyboard
no beeps at start up
the pwr lite on start button will only glow yellow
* a couple things i do see are, the LED on mobo is lit, and the lite at the network card lites when plugged it to network cable.
hope this is enough info, if more needed send pm or i'll check thread often.
the computer is a DELL DIMENSION E521
ANY HELP WOULD BE GREATLY APPRECIATED
THANKS AGAIN,
REDBONE
no monitor
no keyboard
THANKS AGAIN,
REDBONE
