Common Shop Tools
+ More Options
Posts
  • DenyP
    • 599
    • Staples, Minnesota 56479
    Common Shop Tools
    DRILL PRESS :
    A tall upright machine useful for suddenly snatching flat metal bar stock out of your hands so that it smacks you in the chest and flings your beer across the room, denting the freshly-painted project which you had carefully set in the corner where nothing could get to it.
    WIRE WHEEL :
    Cleans paint off bolts and then throws them somewhere under the workbench with the speed of light. Also removes fingerprints and hard-earned calluses from fingers in about the time it takes you to say, "Oh, ****!"
    SKILL SAW :
    A portable cutting tool used to make studs too short.
    PLIERS:
    Used to round off bolt heads. Sometimes used in the creation of blood-blisters.
    BELT SANDER :
    An electric sanding tool commonly used to convert minor touch-up jobs into major refinishing jobs.
    HACKSAW :
    One of a family of cutting tools built on the Ouija board principle... It transforms human energy into a crooked, unpredictable motion, and the more you attempt to influence its course, the more dismal your future becomes.
    VISE-GRIPS :
    Generally used after pliers to completely round off bolt heads. If nothing else is available, they can also be used to transfer intense welding heat to the palm of your hand.
    OXYACETYLENE TORCH:
    Used almost entirely for lighting various flammable objects in your shop on fire. Also handy for igniting the grease inside the wheel hub out of which you want to remove a bearing race.
    TABLE SAW :
    A large stationary power tool commonly used to launch wood projectiles for testing wall integrity.
    HYDRAULIC FLOOR JACK :
    Used for lowering an automobile to the ground after you have installed your new brake shoes, trapping the jack handle firmly under the bumper.
    BAND SAW:
    A large stationary power saw primarily used by most shops to cut good aluminum sheet into smaller pieces that more easily fit into the trash can after you cut on the inside of the line instead of the outside edge.
    TWO-TON ENGINE HOIST :
    A tool for testing the maximum tensile strength of everything you forgot to disconnect.
    PHILLIPS SCREWDRIVER :
    Normally used to stab the vacuum seals under lids or for opening old-style paper-and-tin oil cans and splashing oil on your shirt; but can also be used, as the name implies, to strip out Phillips screw heads.
    STRAIGHT (Flathead) SCREWDRIVER :
    A tool for opening paint cans. Sometimes used to convert common slotted screws into non-removable screws and butchering your palms.
    PRY BAR :
    A tool used to crumple the metal surrounding that clip or bracket you needed to remove in order to replace a 50 cent part.
    HOSE CUTTER :
    A tool used to make hoses too short.
    HAMMER :
    Originally employed as a weapon of war, the hammer nowadays is used as a kind of divining rod to locate the most expensive parts adjacent the object we are trying to hit.
    UTILITY KNIFE :
    Used to open and slice through the contents of cardboard cartons delivered to your front door; works particularly well on contents such as seats, vinyl records, liquids in plastic bottles, collector magazines, refund checks, and rubber or plastic parts. Especially useful for slicing work clothes, but only while in use.
    Son of a bitch TOOL :
    Any handy tool that you grab and throw across the garage while yelling "Son of a bitch" at the top of your lungs. It is also, most often, the next tool that you will need.
    Deny
    Hi Deny,
    there's also this one:-
    ELECTRIC SOLDERING IRON
    A tool used to drip molten lead onto bare skin to prove that a real man can scream like a girl if sufficiently motivated.
      Forgot a few...
      ELECTRIC DRILLMOTOR :
      Handy tool for making holes almost, but not quite, where you want them. Related to the drill press; main difference is the object it flings is you. For those with ZZ Top-type beards or long hair, also makes nice chin/head art.
      HAND-HELD GRINDER :
      Combines most of the features of the wire wheel and belt sander in one handy tool. If set down while still running, will clean your work area of extra parts/tools.
      '78E original owner
      • jmnjrpa
        • Jun 2009
        • 863
        • Lewisville, Texas
        Yep! Now I know what it is for!
        '81 1100 MNS - "Midnight XSpress"
        Original except:
        Big John
          And one more...
          ELECTRIC ARC WELDER :
          Related to the Oxyacetylene Torch. Additional benefit is to allow you to demonstrate your free-form dancing techniques when a bit of slag gets inside your clothing.
          '78E original owner
          • ccogswel
            • Jun 2005
            • 302
            • Bowling Green, Ky
            Need to add this to the screw driver "also puts holes in inner tubes"
            Shop Press: Allows you to find out the breaking resistance of any part you are trying to press a bearing into.
            Carb Cleaner: The next thing to Pepper Spray when it get's into your eye's.
            Drop Light: The only tool that knows when to blow a bulb just when you need it the most.
            Tool Box: A place to store all your tools that you can never find when you need them.
            Chris
            79 XS1100 Standard aka: Mutt
            Gimme Fuel Gimme Fire!
            • XSokieSPECIAL
              • Jun 2009
              • 1631
              • Tulsa, OK
              Ha-ha-ha-ha-ha..............Obviously words of people with advanced mechanical skills...................
              • Guy_b_g
                • May 2007
                • 790
                • Beverly Hills, Florida
                I learned from personal experience that if you try to hold back even a 1/2" DeWalt when it catches a burr, bad things can happen. Had one kick back on me a couple years ago while drilling through tubing and didn't let go quickly enough. It snapped a bone in my hand, just like that *. The guy holding the part for me even heard it snap. I said "ouch" (or something like that). Now when I drill I do it left handed so if it catches, it spins out of my grip instead of into it.
                HAND-HELD GRINDER :
                Even more useful for irritating co workers with showers of well aimed sparks, bits of welding spatter and occasional shrapnel from cutting wheels.
                Guy
                '78E
                • oseaghdha
                  • 1075
                  • N43.02.5,W88.14.2
                  How about the Easy Out?
                  Useful for making damn certain that the broken bolt will NEVER come out.
                  XS1100SF
                  XS1100F
                  • jmnjrpa
                    • Jun 2009
                    • 863
                    • Lewisville, Texas
                    Hey,
                    You guys are giving me some ideas!
                    Original except:
                    Big John
                      After 30+ years in construction, I've experienced or seen every drillmotor horror-story you can imagine....
                      There's two brands you always had to be real careful with; Milwaukee and Thor. The Thors were bad because they featured all-ball-bearing construction and the damn things would run for 30 seconds after you released the trigger. And they usually featured 'D' handles like a sawzall, so if they hung up, you had no leverage. The contractors hated to give them up as they lasted almost forever, but they finally legislated them off the job due to all the broken wrist claims. Thor went out of business because they were too expensive for the consumer market and didn't have enough money to update their line.
                      But the Milwaukees are the dangerous ones if not treated with utmost respect. They have the most powerful motors out of all the brands out there, and broken bones, getting flung off a ladder, or missing teeth could be your reward if you didn't pay attention. With these, the cardinal rule was: don't let go. Use both hands, get a death-grip, and have another guy standing by to unplug it if things got hairy. Getting hit in the head when the handle came around was worse than hanging on for dear life. These all have side handles (you are using the side handle, right?) If possible, we'd use a lesser brand as those you could stop. Might burn up a few, but safer.
                      The real killer is the Milwaukee 'Hole Hawg'. 5/8" capacity, two-speed gearbox, angle head design. On high speed, pay attention but you can hold it if it hangs up. Low speed? Better have that death-grip, as I've seen one of these twist off a 1/2" drill shank like it was nothing. But if you have something that nothing else short of a drill press will go through, this is the one...
                      '78E original owner
                      • Guy_b_g
                        • May 2007
                        • 790
                        Wasn't using a side handle, was holding up one end of a piece of 2 1/2" square tubing that had been drilled to match a bracket, but with too small a hole. Had to drill one handed, and knew it was probably going to hang up, and still wasn't quick enough letting go. I've found that drilling left handed will allow the drill to escape your grip if you have to drill one handed.
                        Otherwise I always used side handles and drilled 2 handed unless it was impossible due to lack of space.
                        Have drilled out concrete with rebar using a big 3/4" Bosch impact drill, you need to brace the side handle against your leg for that.
                        Not working there any more, company shut down 6 months ago.
                        Guy
                        '78E
                        • GARTHXS
                          • 1631
                          • Seattle
                          dont forget!
                          the worst one is the one who is operating the one on the list , I can hamhand almost any screw beyond operation , and quite often I hurt myself when I am nowhere near any hand tools
                          91 kwaka kz1000p
                          Stock
                          ( Insert clever quote here )
                            For drilling thin (up to 1/4") metal in larger sizes, I really like step drills AKA uni-bits. Much smoother action and leaves a rounder hole. I'll drill a pilot hole, then finish with the step bit. They don't hold up as well and can leave a pretty big burr, but in a hand-held drill they're the ticket.
                            Roto-hammers.... When I started, the smaller, lighter ones were just getting popular; the first electric one I ever used must have weighed 40 lbs if it weighed an ounce, and max capacity was 1 1/4". Some of the cheaper early models didn't have clutches and would beat you to death. I remember drilling a 1 1/8" hole through a 6" slab in an occupied building and hitting a piece of rebar. Normally, you'd move the hole to miss, but we had already started the hole and we couldn't move it because of the floor finish. Took over an hour to chew through the rebar and both of my legs looked like somebody had beat me the next day. Plus all the ungodly racket it made. The real bad part? All this was happening in an occupied ward at a mental hospital, and things got really strange before we got out of there. The noise did not improve their mental state.....
                            '78E original owner
